Official Carisma GT24B Racers Edition White 1/24 Scale 4WD Brushless Buggy Thread
  • jbaartz
    • Sep 2020
    • 488
    GT24B Racers Edition White 1/24 Scale 4WD Brushless Buggy-RTR by Carisma - CIS81668
    Version Info: This car is delivered as completely “RTR” and there is nothing additional required for completion.
    Honey, I shrunk the 1/8 scale buggy! Motion RC delivers the fun of driving a racing buggy in small spaces with a micro version of this globally-popular racing class. The Carisma GT24B includes brushless power as standard equipment, and with features like 2.4Ghz radio gear, a durable and precise micro steering servo, grippy micro-pin racing tires and ball bearing-equipped 4WD transmission with slipper clutch, these 1/24th scale machines not only look the part, but they also perform well beyond expectations. It's the perfect vehicle to create a racetrack in a rec room or garage or turn the backyard into a massive off road course. The size and portability of the GT24 series means big fun, wherever you want to run it. The GT24B arrives truly ready to run, including a 7.2V NiMH battery, USB charger, tools, spares and even four AA batteries for the transmitter.
    • Carisma CTX-2000 2.4GHz Transmitter
    • MRS-24BL 2-in-1 RX/ESC (Brushless)
    • 8000kv Mini-130 Brushless motor (Sensorless)
    • 7.2V NiMH Micro Stick Pack Included
    • Low-Maintenance Friction Dampers
    • High Traction Micro Pin Racing Tires
    • 4 x AA batteries for TX Included
    • USB Charger Included
    • Carisma MS-24B Steering Servo
    • Full Ball Bearings
    • Carisma GT24B Racers Edition White 1/24 Scale 4WD Brushless Buggy - RTR
    • Carisma MRS-24BL 2-in-1 RX/ESC (Brushless)
    • Carisma 8000kv Brushless motor
    • USB battery Charger
    • Complete Ball Bearings
    Requires:
    • Nothing else to buy!
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 15 Minutes
    Model Scale 1/24
    Length 180mm / 7.0in
    Width 107mm / 4.1in
    Height 64mm / 2.5in
    Weight (No Battery) 200g / 7.1oz
    Wheelbase 119mm / 4.6in
    Ground Clearance 7mm / 0.27in
    Body Polycarbonate, factory painted and decorated
    Chassis Nylon composite tub
    Drivetrain 4WD
    Wheel Hex Size N/A
    Tire Tread Multi-surface micro pin
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Friction damper
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 12T
    Spur Gear 59T
    Differential Composite Gear Differential
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control MRS-24BL Brushless 2-in-1 RX/ESC
    Motor 8000kv Brushless motor
    Battery 7.2V NiMH
    Servos Carisma MS-24B
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time Less Than 15 minutes
    Recommended Environment Indoors/Outdoors
