Official Carisma GT24 RS Retro 1/24 Scale 4WD Brushless Rally Car Thread
  • jbaartz
    • Sep 2020
    • 488
    GT24 RS Retro 1/24 Scale 4WD Brushless Rally Car - RTR by Carisma - CIS80468
    Version Info: This car is delivered as completely “RTR” and there is nothing additional required for completion.
    Motion RC offers the fun and excitement of driving a retro rally car in a micro package! The GT24 RS is a 1/24th Retro Micro Rally Car that's inspired by the classic Rally Car era of 1970's and 1980's Rally Car history. The RS-style body is a nostalgic nod to the classic RWD Rally pioneers and although this version is 4WD, it provides an optimum combination of retro looks and a modern RC drivetrain.
    With brushless power as standard, and sporting features like 2.4Ghz radio gear, a fast responsive hobby grade steering servo, Rally Pin tires and ball bearing-equipped 4WD transmission, these 1/24th Rally Cars not only look the part, but they also perform way beyond what you might expect from a micro vehicle. It's the perfect vehicle to allow you to create your own special stage in the living room or turn a backyard or the local park into a complete Retro Rally Championship. The size and portability of the GT24 means big fun, wherever you want to run it. The GT24RS arrives truly ready to run, including a 7.2V NiMH battery, USB charger, tools, spares and even four AA batteries for the transmitter.
    • Carisma CTX-2000 2.4GHz Transmitter
    • MRS-24BL 2-in-1 RX/ESC (Brushless)
    • 8000kv Mini-130 Brushless motor (Sensorless)
    • 7.2V NiMH Micro Stick Pack Included
    • Low-Maintenance Friction Dampers
    • High Traction All-Terrain Rally Pin Tires
    • 4 x AA batteries for TX Included
    • USB Charger Included
    • Carisma MS-24B Steering Servo
    • Full Ball Bearings
    • Carisma GT24 RS Retro 1/24 Scale 4WD Brushless Rally Car - RTR
    • Carisma MRS-24BL 2-in-1 RX/ESC (Brushless)
    • Carisma 8000kv Brushless motor
    • USB battery Charger
    • Complete Ball Bearings
    Requires:
    • Nothing else to buy!
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 15 Minutes
    Model Scale 1/24
    Length 185mm / 7.2in
    Width 89mm / 3.4in
    Height 70mm / 2.7in
    Weight (No Battery) 200g / 7.1oz
    Wheelbase 121mm / 4.7in
    Ground Clearance 7mm / 0.27in
    Body Polycarbonate, factory painted and decorated
    Chassis Nylon composite tub
    Drivetrain 4WD
    Wheel Hex Size N/A
    Tire Tread Multi-surface rally pin
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Friction damper
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 12T
    Spur Gear 59T
    Differential Composite Gear Differential
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control MRS-24BL Brushless 2-in-1 RX/ESC
    Motor 8000kv Brushless motor
    Battery 7.2V NiMH
    Servos Carisma MS-24B
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time Less Than 15 minutes
    Recommended Environment Indoors/Outdoors
