Official Carisma GT24 Hyundai i20 WRC 1/24 Scale 4WD Brushless Rally Car Thread
  • jbaartz
    • Sep 2020
    • 488
    GT24 Hyundai i20 WRC 1/24 Scale 4WD Brushless Rally Car - RTR by Carisma - CIS80168
    Version Info: This car is delivered as completely “RTR” and there is nothing additional required for completion.
    Experience the next small thing in radio control from Motion RC with Carisma’s officially-licensed Hyundai i20 1/24 scale World Rally Championship RTR. With brushless power as standard, and sporting features like 2.4GHz radio gear, a fast and responsive hobby-grade steering servo, all-terrain Rally Pin tires, and a fully ball bearing-equipped 4WD transmission, these cars not only look the part, but they also perform way beyond most perceptions of 1/24 scale RC vehicles. Now you can create your own special rally stage in your family room or turn your backyard into a complete WRC championship. The size of these cars can mean only one thing...huge fun!
    • KD PROPO CTX-2000 2.4GHz Transmitter
    • MRS-24BL 2-in-1 RX/ESC (Brushless)
    • 8000kv Mini-130 Brushless motor (Sensorless)
    • 7.2V NiMH Micro Stick Pack Included
    • Low-Maintenance Friction Dampers
    • High Traction Rally Mini Pin Tires
    • 4 x AA batteries for TX Included
    • 5v USB Charger Included
    • Hobby Grade Steering Servo
    • Officially Licensed Body
    • Full Ball Bearings
    • Carisma GT24 Hyundai i20 WRC 1/24 Scale 4WD Brushless Rally Car - RTR
    • Carisma KD PROPO CTX-2000 2.4GHz Transmitter
    • Carisma MRS-24BL 2-in-1 RX/ESC (Brushless)
    • Carisma 8000kv Brushless motor
    • USB Charger
    • Complete Ball Bearings
    Requires:
    • Nothing else to buy!
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 15 Minutes
    Model Scale 1/24
    Length 198mm / 7.7in
    Width 91mm / 3.5in
    Height 76mm / 2.9in
    Weight (No Battery) 200g / 7.1oz
    Wheelbase 121mm / 4.7in
    Ground Clearance 7mm / 0.27in
    Body Polycarbonate, factory painted and decorated
    Chassis Nylon composite tub
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 36.3mm / 1.4in x 12.5mm / 0.49in
    Wheel Hex Size N/A
    Tire Tread Multi-surface rally pin
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Friction damper
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 12T
    Spur Gear 59T
    Differential Composite Gear Differential
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control MRS-24BL Brushless 2-in-1 RX/ESC
    Motor 8000kv Brushless motor
    Battery 7.2V NiMH
    Servos Carisma MS-24B
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time Less Than 15 minutes
    Recommended Environment Indoors/Outdoors
