GT24TR 1/24 Scale 4WD Brushless Truggy - RTR by Carisma - CIS58168
Version Info: This car is delivered as completely “RTR” and there is nothing additional required for completion.
Motion RC offers the fun and excitement of driving a Truggy in micro package! The GT24TR from Carisma takes micro RC tech to an elevated level of performance, durability, and convenience, and wraps it in a truggy theme. Turn your ping pong table into a racetrack or bash it on the street or sidewalk. The micro all-terrain racing tires help to transfer the power of the 8000kV brushless motor and 4wd drivetrain, while precision friction dampers keep the suspension plush. Delivering precise control of this micro racing beast is the included CTX8000 2.4GHz transmitter, with an ultra-fast micro steering servo and brushless ESC with reverse. The chassis comes complete with full ball bearings, gear differentials, center slipper, and colorful screen-printed body with high-downforce wing. The GT24TR arrives truly ready to run, including a 7.2V NiMH battery, USB charger, tools, spares and even four AA batteries for the transmitter.
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : Less Than 15 Minutes
- Carisma CTX-8000 2.4GHz Transmitter
- MRS-24BL 2-in-1 RX/ESC (Brushless)
- 8000kv Mini-130 Brushless motor (Sensorless)
- 7.2V NiMH Micro Stick Pack Included
- Low-Maintenance Friction Dampers
- High Traction All-Terrain Tires
- 4 x AA batteries for TX Included
- USB Charger Included
- Carisma MS-24B Steering Servo
- Full Ball Bearings
- Carisma GT24TR 1/24 Scale 4WD Brushless Truggy - RTR
- Carisma MRS-24BL 2-in-1 RX/ESC (Brushless)
- Carisma 8000kv Brushless motor
- USB battery Charger
- Complete Ball Bearings
- Nothing else to buy!
| Model Scale | 1/24 |
| Length | 185mm / 7.2in |
| Width | 131mm / 5.1in |
| Height | 70mm / 2.7in |
| Weight (No Battery) | 200g / 7.1oz |
| Wheelbase | 121mm / 4.7in |
| Ground Clearance | 7mm / 0.27in |
| Body | Polycarbonate, factory painted and decorated |
| Chassis | Nylon composite tub |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | N/A |
| Wheel Hex Size | N/A |
| Tire Tread | Multi-surface rally pin |
| Bushing Material | N/A |
| Suspension | 4-wheel independent |
| Shock Type | Friction damper |
| Transmission | 4WD Shaft-driven |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | 12T |
| Spur Gear | 59T |
| Differential | Composite Gear Differential |
| Ball Bearings | Complete |
| Brakes | Electronic |
| Electronic Speed Control | MRS-24BL Brushless 2-in-1 RX/ESC |
| Motor | 8000kv Brushless motor |
| Battery | 7.2V NiMH |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | Carisma MS-24B |
| Radio | 2 Channel (included) |
| Lights | No |
| Sound | No |
| Water Resistant | No |
| Skill Level | Beginner |
| Assembly Time | Less Than 15 Minutes |
| Recommended Environment | Indoors/Outdoors |
.png)
