GT24R 1/24 Scale 4WD Rally Car - RTR by Carsima - CIS57968
Version Info: This car is delivered as completely “RTR” and there is nothing additional required for completion.
Motion RC offers the fun and excitement of rally driving in micro package! Carisma's GT24R takes RC technology to the next level in performance and durability and wraps it in a rally racing motif. Race on your ping pong table or attack your own rally stages on streets or sidewalks. The micro all-terrain racing tires help transfer the power produced by an 8000kV brushless motor and 4WD drivetrain, while precision friction dampers keep the suspension plush. This micro racing beast can be controlled precisely with an included KD PRO transmitter with a new ultra-fast micro steering servo and brushless ESC with reverse. The center slipper, gear differentials, and colorful screen-printed body with high-downforce wing are included to complete the package. The GT24R arrives ready to run, including a 7.2V NiMH battery, a USB charger, tools, spares, and four AA batteries for the transmitter.
Features:
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : Less Than 15 Minutes
Features:
- KD PROPO CTX-2000 2.4GHz Transmitter
- MRS-24BL 2-in-1 RX/ESC (Brushless)
- 8000kv Mini-130 Brushless motor (Sensorless)
- 7.2V NiMH Micro Stick Pack Included
- Low-Maintenance Friction Dampers
- High Traction Rally Mini Pin Tires
- 4 x AA batteries for TX Included
- USB Charger Included
- Carisma MS-24B Steering Servo
- Full Ball Bearings
- Carisma GT24R 1/24 Scale 4WD Rally Car - RTR
- Carisma KD PROPO CTX-2000 2.4GHz Transmitter
- Carisma MRS-24BL 2-in-1 RX/ESC (Brushless)
- Carisma 8000kv Brushless motor
- USB battery Charger
- Complete Ball Bearings
- Nothing else to buy!
| Model Scale | 1/24 |
| Length | 208mm / 8.1in |
| Width | 112mm / 4.3in |
| Height | 80mm / 3.1in |
| Weight (No Battery) | 200g / 7.1oz |
| Wheelbase | 119mm / 4.6in |
| Ground Clearance | 7mm / 0.27in |
| Body | Polycarbonate, factory painted and decorated |
| Chassis | Nylon composite tub |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 36.3mm / 1.4in x 12.5mm / 0.49in |
| Wheel Hex Size | N/A |
| Tire Tread | Multi-surface rally pin |
| Bushing Material | N/A |
| Suspension | 4-wheel independent |
| Shock Type | Friction damper |
| Transmission | 4WD Shaft-driven |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | 12T |
| Spur Gear | 59T |
| Differential | Composite Gear Differential |
| Ball Bearings | Complete |
| Brakes | Electronic |
| Electronic Speed Control | MRS-24BL Brushless 2-in-1 RX/ESC |
| Motor | 8000kv Brushless motor |
| Battery | 7.2V NiMH |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | Carisma MS-24B |
| Radio | 2 Channel (included) |
| Lights | No |
| Sound | No |
| Water Resistant | No |
| Skill Level | Beginner |
| Assembly Time | Less Than 15 minutes |
| Recommended Environment | Indoors/Outdoors |
