Official HPI Racing RS4 Sport 3 Flux Audi E-Tron Vision GT 1/10 Scale 4WD Brushless Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    RS4 Sport 3 Flux Audi E-Tron Vision GT 1/10 Scale 4WD Brushless Car - RTR from HPI Racing - HPI160202
    Version Info: This car is delivered as "RTR", however it does require a 2S (7.4V) or 3S (11.1V) LiPo battery and a battery charger, purchased separately (see Requires below for details).
    Motion RC is proud to offer HPI Racing’s most ambitious, detailed and realistic official scale replica partnership yet! When Audi designers pushed themselves to turn a best selling video game car into a reality, HPI's designers followed suit with the dream that this amazing electric race machine could also hit the the real-world track in 1:10th form!
    Since the dawn of Formula E, electric powered racing has been growing across the motorsport world. What better way to take RC to a generation of sim racers than with the very real, incredibly fast, utterly sublime Sport 3 Flux Audi e-tron Vision GT!
    The Sport 3 Flux features full-time shaft driven 4WD, a fully sealed drivetrain, waterproof 2.4 GHz electronics/radio gear, fully independent double wishbone suspension and adjustable oil-filled shocks so it’s Ready to Rock in any condition. Propelling the Sport 3 to speeds over 113km/h (70mph) is the Flux MMH-4000KV motor, controlled by the waterproof Flux EMH-3S LiPo-ready speed controller. An enclosed box houses the 2.4GHz radio receiver, ensuring that you have constant control through the HPI pistol-grip steering wheel transmitter.
    Officially Licensed Audi Sport Replica Wheels
    Not only is the e-tron one of HPI's most ambitious and detailed bodies, their designers have captured every last detail, right down to the Quattro emblazoned racing wheels. Wrapped around these beauties is a set of treaded rubber tires for maximum grip on just about every paved surface. You'll get great acceleration, braking and cornering performance from these semi-slick, grippy rubber tires!
    One-Piece Molded Chassis
    The Sport 3 main chassis is formed from a single piece of reinforced plastic and features the drivetrain tunnel molded right down the middle, just like a real car. It's a step beyond any plastic tub chassis car available today.
    Low Profile Layout Design
    One of the ways we gave the Sport 3 the best possible handling was to make sure all the components fit as low as possible in the chassis. This gives the car an amazingly low center of gravity for enhanced cornering capabilities.
    HPI Flux Technology
    The Sport 3 Flux is fitted with the awesome Flux MMH-4000 motor, one of HPI's most powerful motors for 1/10th scale cars. Thanks to the robust Flux EMH-3S speed controller, you can strap in your choice of 2S or 3S LiPo power (or a 7.2v-8.4v NiMH battery with a Dean's plug) to give the car an unbelievable power out of the turns and speeds of up to 70mph (requires the High Speed Gear Set - sold separately, and a 3S LiPo battery pack) on the straight, when using optional gearing!
    Tough Front End Suspension
    The Sport front end uses the strong C-hub style suspension seen on the latest RC touring cars, with a vertical ball stud camber mount that lets you change the front end roll center – which is a critical racing adjustment that allows the Sport 3 to be a step above other sport-level RC touring cars. The suspension arm also features multiple shock mounting holes for easy shock angle adjustment.
    Metal-Shielded Ball Bearings
    The Sport 3 is fully fitted with a set of metal-shielded ball bearings for maximum efficiency. The metal shields keep the dust away from the internals while the smooth precision bearings provides for optimum power delivery from the power source out into the driveline.
    • Pre-assembled 1/10th scale car
    • Officially licensed unique Audi Sport replica wheels
    • One-piece molded chassis
    • Flux MMH-4000 motor
    • Full-time four-wheel drive
    • Sealed shaft drivetrain
    • 4-gear metal differentials
    • Double-wishbone fully adjustable suspension
    • Oil-filled threaded shocks
    • Tunable read suspension
    • Double bellcrank steering
    • Rugged spring-loaded servo saver
    • Aluminum motor mount
    • Metal-shielded ball bearings
    • HPI Racing RS4 Sport 3 FLUX Audi E-Tron Vision GT 1/10 Scale 4WD Brushless Car - RTR
    • HPI pistol-grip transmitter with interference-free 2.4GHz technology
    • Painted Audi E-Tron Vision GT Body
    • 4x AA Batteries
    • Instruction manual
    AGE LEVEL :11 and up
    SKILL LEVEL :Intermediate
    BUILD TIME :Less Than 1 Hour
    Model Scale 1/10
    Length 431mm / 17in
    Width 200mm / 7.9in
    Height 127mm / 5in
    Weight (No Battery) N/A
    Wheelbase 254mm / 10in
    Ground Clearance N/A
    Body Polycarbonate, factory painted and decorated
    Chassis Reinforced plastic
    Drivetrain 4WD
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension Fully independent double wishbone
    Shock Type Oil-filled, coilover, adjustable
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Metal bevel gear
    Ball Bearings Full metal-shielded
    Brakes N/A
    Electronic Speed Control Waterproof Flux EMH with T connector
    Motor 4000Kv Brushless Inrunner
    Battery 3S LiPo with T-connector (required)
    Servos Water-resistant
    Radio TF-41 2.4GHZ 3CH Radio (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time Less Than 1 Hour
