Official HPI Racing RS4 Sport 3 1969 Mustang RTR-X 1/10 Scale 4WD Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    RS4 Sport 3 1969 Ford Mustang RTR-X 1/10 Scale 4WD Car - RTR from HPI Racing - HPI120102
    Version Info: This model is offered Ready to Run, including battery, charger, and 4 AA transmitter batteries. There is nothing else to buy!
    World Champion Drifter Vaughn Gittin Jr. and the Need for Speed crew teamed up to build a one-of-a-kind, fully-functional Street, Track and Drift machine, and this is the official, authorized RC replica, only from HPI and available from Motion RC!
    Balancing 5.0 liters of tire-shredding American horsepower with vintage American, Japanese, European and Drift culture inspired design influences, Vaughn has incorporated state-of-the-art technology while retaining a nostalgic feel into his vision for the 1969 Ford Mustang's timeless body. The RTR-X was designed and built from the ground up to be driven hard; the RTR-X is NOT a trailer queen.
    While Vaughn will be the only one behind the wheel thrashing it, the entire world will be able to enjoy driving the HPI 1/10th scale RTR-X. The RS4 Sport 3 is a fun, easy to drive and simple to maintain street car, featuring a completely pre-assembled race car chassis for amazing fun and loads of action!
    HPI has packed in all the latest features like 2.4GHz control and complete waterproof protection! The chassis is factory assembled right out of the box, making the RS4 Sport 3 a quick and easy way to get straight into driving, racing and honing your skills! This is a complete racing machine that looks and drives just like the real thing!
    Official Replica of the Amazing RTR-X
    The RS4 Sport 3 features a pre-painted 1969 Ford Mustang RTR-X muscle car body with authentic detailing and decals. The body comes completely trimmed and mounted for the ultimate in ease, and a functional racing wing is fitted for supreme control at all speeds.
    Pre-Mounted Drift and Grip Tires
    The RS4 Sport 3 1969 Ford Mustang RTR-X is fitted with a set of HPI Spec-Grip treaded rubber tires for maximum grip on just about every paved surface. If going sideways is more your style, we also include a second set of wheels fitted with HPI T-Drift tires.
    One-Piece Molded Chassis
    The Sport 3 main chassis is formed from a single piece of reinforced plastic and features the drivetrain tunnel molded right down the middle, just like a real car. It's a step beyond any plastic tub chassis car available today.
    Low Profile Layout Design
    One of the ways we gave the Sport 3 the best possible handling was to make sure all the components fit as low as possible in the chassis. This gives the car an amazingly low center of gravity for enhanced cornering capabilities.
    Tough Front End Suspension
    The Sport front end uses the strong C-hub style suspension seen on the latest RC touring cars, with a vertical ball stud camber mount that lets you change the front end roll center – which is a critical racing adjustment that allows the Sport 3 to be a step above other sport-level RC touring cars. The suspension arm also features multiple shock mounting holes for easy shock angle adjustment.
    Metal-Shielded Ball Bearings
    The Sport 3 is fully fitted with a set of metal-shielded ball bearings for maximum efficiency. The metal shields keep the dust away from the internals while the smooth precision bearings provides for optimum power delivery from the power source out into the driveline.
    • Pre-Assembled 1/10th scale car
    • Officially licensed 1969 Ford Mustang RTR-X muscle car body with authentic detailing and decals
    • One-piece molded chassis
    • Pre-mounted drift and grip tires
    • Low profile layout design
    • 2S (7.4V) LiPo battery capable (LiPo adapter plug not included)
    • Full-time four-wheel drive
    • Sealed shaft drivetrain
    • 4-gear metal differentials
    • Double-wishbone fully adjustable suspension
    • Oil-filled threaded shocks
    • Tunable read suspension
    • Double bellcrank steering
    • Rugged spring-loaded servo saver
    • Aluminum motor mount
    • Metal-shielded ball bearings
    • HPI Racing RS4 Sport 3 1969 Ford Mustang RTR-X 1/10 Scale 4WD Car - RTR
    • HPI pistol-grip transmitter with interference-free 2.4GHz technology
    • Painted 1969 Ford Mustang RTR-X Body
    • 4x AA Batteries
    • 7.2V 2000mAh NiMH battery
    • Wall battery charger
    • Instruction manual
    Product Specifications:
    AGE LEVEL :11 and up
    SKILL LEVEL :Intermediate
    BUILD TIME :Less Than 1 Hour
    Model Scale 1/10
    Length 431mm / 17in
    Width 200mm / 7.9in
    Height 127mm / 5in
    Weight (No Battery) N/A
    Wheelbase 254mm / 10in
    Ground Clearance N/A
    Body Polycarbonate, factory painted and decorated
    Chassis Reinforced plastic
    Drivetrain 4WD
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension Fully independent double wishbone
    Shock Type Oil-filled, coilover, adjustable
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Metal bevel gear
    Ball Bearings Full metal-shielded
    Brakes N/A
    Electronic Speed Control Waterproof SC-3SWP2
    Motor 540 Firebolt 15T
    Battery 7.2V 2000 mAh NiMH battery (included)
    Servos Water-resistant
    Radio TF-41 2.4GHZ 3CH Radio (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time Less Than 1 Hour
