Official Kyosho Scorpion 2014 1/10 Scale 2WD Off-Road Buggy Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	kyosho-scorpion-2014-1-10-scale-2wd-off-road-buggy-kit-motion-rc-34320455041209.jpg
    Version Info: This buggy is a KIT, and as such will require electronics, paint and other equipment (see Requires below for details).
    The legendary Kyosho Scorpion is credited with taking the racing buggy category into the realm of pure motorsports. Even after 30 years since it was first released in 1982, the indelible mark of the Scorpion still exists with its many fans around the world. While maintaining the wild and free spirit of the original baja buggy style and chassis layout, the 2014 version features the latest in performance technology and sacrifices nothing in speed and endurance on modern buggy racing tracks.
    Externally it may look like the original Scorpion with its semi-trailing suspension arms, but the advanced 6061T6 forged aluminum material delivers futuristic levels of strength, rigidity and durability. Following the original design, the Scorpion 2014 features a new two-piece die-cast aluminum gearbox with differential gears. In addition, the included slipper clutch protects the transmission as well as delivers efficient traction that takes the Scorpion s control feel and durability to a new higher level. Precision 48 pitch gears reduce traction pulsation for direct driving control characteristics while the flat under surface of the countersunk chassis has no protruding screw heads for minimal contact resistance and scraping, resulting in higher durability. Stainless shafts combine with aluminum cylinders in the oil shocks for smooth stroke from top to bottom and running performance worthy of a true racing buggy.
    Like the original Scorpion, the 2014 version is packaged as an unassembled kit, but nearly all tapping screws and nuts have been replaced with the improved lightweight and security a hex screws. From experts familiar with the Scorpion’s standard of performance to present-day drivers unaware of the Scorpion legend, all will enjoy the Scorpion experience that inspired so many and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Improved Driveability
    Front and rear suspension arms are made from 6061T6 aluminum to realize improved rigidity, durability and lightness. Wide front tread delivers superior driving stability.
    Two-Piece Diecast Aluminum Gearbox
    Includes two-piece diecast aluminum gearbox with built-in diff gears. Included slipper clutch can be set according to various surface types and conditions.
    Superior Efficiency
    Sintered alloy and nylon combine in 48 pitch gears to deliver superior efficiency. Includes two gears for high-speed and low-speed settings. Ball differential is also available as an optional upgrade.
    6061T6 Aluminum
    Main frame, front and rear shock stays and sub frame plate are made from 6061T6 aluminum. Underside of chassis is countersunk for a flat finish.
    Excellent Damping
    Aluminum cylinders and stainless shafts in the oil shocks produce excellent damping. Delivers smooth movement through the entire stroke range.
    New Tires
    Original style combines with a new pattern on high grip tires. Rear tires are equipped with inner sponges and the molded wheels feature a satin chrome finish.
    • Revival of the famous Kyosho Scorpion. 2014 version upgraded throughout
    • Kit includes pre-assembled gearbox and oil shocks (shock oil sold separately)
    • 6061T6 forged aluminum suspension arms
    • Two-piece diecast aluminum gearbox with built-in diff gears
    • Slipper clutch protects gears and provides traction setting options
    • Oil shocks with aluminum cylinders and stainless shafts deliver smooth movement
    • Countersunk surface allows screws to be seated flat
    • Lightweight design from reduction in tapping screws and nuts
    • Near complete use of hex screws provides secure assembly
    • Inner sponges included with rear tires
    • Includes newly developed block pattern high-grip compound tires
    • Ball diff from Ultima RB can be installed as an optional upgrade
    • Kyosho Scorpion 2014 1/10 Scale 2WD Off-Road Buggy - Kit
    • Pre-assembled kit (gear box and oil shocks are pre-assembled)
    • Clear polycarbonate body
    • Decals
    • L-shape hex wrench
    • Cross wrench
    • Shock wrench
    • Shock oil
    • Grease
    • Threadlock glue
    Requires:
    • 2-channel R/C system (1x servo and 1x ESC)
    • 540 Size Motor (20T-27T recommended)
    • ESC compatible with motor
    • Battery pack for chassis
    • Paint for painting the polycarbonate body
    • Batteries for transmitter
    • Tools (1.5, 2, 2.5mm hex wrench driver)
    • NiMH compatible battery charger - we recommend the SkyRC B6AC V2 50W 6 Cell (6S) AC/DC LiPo Battery Charger
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 1 Hour
    Model Scale 1/10
    Length 398mm / 15.6in
    Width 236mm / 9.2n
    Height 145mm / 5.7in
    Weight (No Battery) 985g / 34.7oz
    Wheelbase 263mm / 10.3in
    Ground Clearance N/A
    Body Clear polycarbonate
    Chassis N/A
    Drivetrain 2WD
    Wheel Size (Diameter x Width) F: 75×20mm / R: 85×41mm
    Wheel Hex Size N/A
    Tire Tread Front: 198mm / Rear: 195mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-Filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio H 6.9:1 / L 8.3:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control ESC compatible with motor (required)
    Motor 540 Motor (20T – 27T recommended) (required)
    Battery NiMH battery (required)
    Servos N/A
    Radio 2-channel radio (required)
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
