Official Team Corally Asuga XLR Large Scale 4WD Monster Buggy Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The Team Corally Asuga XLR is a high-performance off-road racing buggy that is designed to dominate any terrain it encounters. With its sleek and aerodynamic design, the Asuga XLR is not only visually appealing but also incredibly agile and fast.
    Fifteen percent bigger than the average 1/8 buggy, with higher ground clearance, more suspension travel, and oversized components-in short, a completely new chassis that still uses the proven drive components of Corally's existing 6S models. Note the many details, and it will soon become clear to you that the ASUGA XLR has set a new standard for RTR RC cars.
    The precision CNC-manufactured aluminum parts, the beautiful red anodization, and the various small details make all the difference.
    Aluminum Chassis with Composite Side Guards
    A 3mm thick, 6065 Aluminum main chassis delivers offers unyielding strength, while the molded side guards protect against dirt and debris from electronics or drivetrain. A mount for the ESC on/off switch has been conveniently molded in the LH side guard.
    Extreme Front Chassis Brace
    The optimized front chassis brace solidifies the front bulkhead, front tower, steering system and Ackermann brace into a rigid, durable assembly that ensures precision steering and the durability that you’ve come to expect from Team Corally. The optimal combination of aluminum and composite components allows drivers to bash with confidence knowing that the Asuga is prepared to dominate anything in its path.
    Heavy Duty Composite Suspension Arms
    Completely re-thinking the arm design, Team Corally designers went all-in toward durability and precision without creating a weight penalty. Further innovations are expressed by the anodized aluminum hinge pin and pivot ball retainers that provide additional strength and security to critical suspension components previously vulnerable during extreme bashing sessions.
    Premium Spring Steel Outdrives
    The Asuga XLR shares drivetrain components proven from use on the venerable Kronos XTR, with S2 Spring Steel providing the ideal combination of tensile strength, light weight, and durability. Enjoy competition-level quality driveline components in a premium bash buggy machine.
    Heavy-Duty Steering Blocks
    The freshly designed composite steering knuckles offer improved fitment and security for the pillow balls and virtually eliminates any chance of them popping out as a result of hard landings or crashes.
    Low Profile Rebel XMS Tires
    Using a common 17mm drive hex, the Asuga XLR features impact resistant 130mm diameter wheels with Rebel XMS high-grip tires designed especially for the rigors of 6S bashing.
    • Modern shaped front and rear bumpers with skid plate
    • Oversized composite steering links and rear camber links
    • Oversized composite camber links
    • Ultra-rigid hybrid chassis brace system
    • Oversized (13mm thick) HD composite suspension arms with aluminum anti-tear rings
    • Front upper arm wing
    • CNC-Machined 8mm aluminum suspension arm holders
    • Oversized HD composite "Pillow Ball" steering blocks with anti pop-out design
    • CNC-Machined 5mm aluminum shock towers
    • The suspension arm holders are fixed to the chassis with M4 screws
    • Super smooth 16mm "Big Bore" aluminum shock absorbers
    • High performance precision CNC-cut hardened steel spur gear
    • Differential spiral bevel gears and pinions
    • Strong and Wear-resistant S2 hardened spring steel drive joints and wheel shafts
    • CNC-Machined adjustable aluminum motor mount
    • Large battery holder
    • Low profile Rebel XMS Off-Road tire
    • Team Corally Asuga XLR Blue Large Scale 4WD Monster Buggy - RTR
    • 2.4 GHz 2-channel transmitter
    • Team Corally Kuron 825 Brushless Motor
    • Hobbywing Torox 185 ESC
    • Team Corally CR-HV 7225 Digital Servo
    • Full set of ball bearings, rubber sealed
    B]Requires:[/B]Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : Less Than 1 Hour
    Model Scale N/A
    Length 574mm / 22.6in
    Width 359mm / 14.1in
    Height 192mm / 7.6in
    Weight (No Battery) 4450g / 157.0oz
    Wheelbase 371mm / 14.6in
    Ground Clearance 75mm / 2.9in
    Body Composite
    Chassis Painted, Decals Applied
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 130mm x 51mm
    Wheel Hex Size 17mm
    Tire Tread Offroad
    Bushing Material N/A
    Suspension Independent
    Shock Type Oil-Filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 3.31 (MOD.1)
    Final Drive Ratio 13.23 (MOD.1)
    Pinion N/A
    Spur Gear N/A
    Differential Oil-Filled
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control Hobbywing Torox 185 ESC
    Motor Team Corally Kuron 825 Brushless
    Battery 4S - 6S LiPo with XT90 connector (required)
    Max Battery Dimensions (L x W x H) 51 x 161 x ?mm (2 x 6.3 x ?")
    Servos Team Corally CR-HV 7225 Digital Servo
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time Less Than 1 Hour
  • Magnus9030
    • Mar 2023
    is this for sale? or is it only for the right price?
    best regards
    Magnus
    Hos Handcrafted Interior designer og bygger vi køkkener og møbler, som er nøjagtigt afstemt og proportioneret til lige præcis dit hjem.
