Official Kyosho 1/27 Scale Mini-Z White Mazda Savanna RX-7 FC3S AWD Car RTR Thread
    Mini-Z White Mazda Savanna RX-7 FC3S 1/27 Scale AWD Car - RTR from Kyosho - KYO32634W
    With just 8 x AAA-size batteries, the MINI-Z Racer allows anyone to enjoy the beautiful style and advanced performance of R/C cars. First launched in 2013, Kyosho has renewed the MINI-Z Racer Sports MR-03 concept to be even more user-friendly and appealing to more drivers with the MINI-Z RWD series! Widely popular body styles in highly detailed body sets create the incredibly realistic model lineup. Including the latest Syncro KT-531P transmitter with steering trim, throttle trim, dual rate, LED control function, the sponge grip of the steering wheel provides comfortable fit for precision control feel.
    The set also includes a car body finished to display-model standard that matches stunning style with the performance, reliability and durability of the MR-03 chassis. The new control program on the circuit board provides linear handling characteristics and can be further enhanced for even easier control by installing the optional gyro unit (MZW446). This series represents the perfect package for a deep dive into the amazing world of R/C cars and your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    KT-531P Transmitter
    Includes stylish Syncro KT-531P transmitter. Features steering / throttle trim as well as steering dual rate adjustment and LED control function.The transmitter also has a Training Mode feature which limits speed of the car for easy learning (Default setting at the time of shipment is Training Mode).
    Gyro Compatibility
    Narrow or Wide Tread
    Can be set to either narrow or wide tread by replacing the front lower and upper plates and steering tie rod. Of course the wheelbase can still be adjusted to suit certain body types. (*Wheelbase change requires optional parts).
    • MINI-Z AWD Readyset based on MA-020 chassis
    • Special circuit board updated with optimized steering control program
    • Chassis features gyro sensitivity adjustment function
    • Drift tires are installed as standard
    • Readyset requires only batteries to be ready for action!
    • Features 2.4GHz Syncro KT-531P transmitter that requires no setup of frequency bands
    • Factory completed body comes with display model quality finish
    • Features VCS (variable camber suspension) that adjusts camber in accordance with suspension stroke
    • Coil spring on front suspension can be easily replaced without tools
    • Wide range of optional parts is available to be installed
    • Kyosho Mini-Z White Mazda Savanna RX-7 FC3S 1/27 Scale AWD Car - RTR
    • R/C unit built-in complete chassis
    • Painted and marked complete body
    • Syncro KT-531P transmitter
    • Mini pylon
    • Pinion gear (15T, 17T, 19T, 21T)
    • Spur gear (27T, 29T, 31T)
    • Spare nut
    • Wheel wrench
    • Pinion removal tool
    Requires:
    Product Specifications:
    AGE LEVEL :11 and up
    SKILL LEVEL :Beginner
    BUILD TIME :None
    Model Scale 1/27
    Length 155mm / 6.1in
    Width 71mm / 2.7in
    Height 48mm / 1.8in
    Weight (No Battery) 193g / 6.8oz
    Wheelbase 90mm / 3.5in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis MR-03
    Drivetrain AWD
    Wheel Hex Size N/A
    Tire Tread F: 58.5mm R: 58.5mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 15T, 17T, 19T, 21T
    Spur Gear 27T, 29T, 31T
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
