Official Kyosho Ultima '87 JJ World Championship Replica 1/10 Scale 2WD Off-Road Buggy Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	kyosho-ultima-87-jj-world-championship-replica-1-10-scale-2wd-off-road-buggy-kit-motion-rc-34873874153657.webp
    Version Info: This buggy is a KIT, and as such will require electronics, paint and other equipment (see Requires below for details).
    American Joel Johnson won his first 2WD class world title at the 2nd Electric Off-Road World Championship in England in 1987 driving a modified Kyosho ULTIMA. Also, TQ’ed this event and finished 1st and 2nd and 3rd.This became known as the ‘JJ Spec’ and was popular with its custom suspension, main chassis and front-rear shock stays that enhanced performance and styling. Only third-party conversion kits were available at the time and even then, it was extremely difficult to completely reproduce the JJ specifications. Now the ‘JJ Spec’ is honored as the 13th model in the Vintage Series to commemorate Kyosho’s 60th anniversary.
    Original Body
    Equipped with the same body used on the Tomahawk 2WD buggy, just like the original. Silver and pink stripe decals with a variety of logos recreate the signature color scheme of the Joel Johnson Spec. Side mirrors from the original have also been recreated.
    FRP Shocks
    FRP shock stays flexibly absorb impact from the shock units and follow the original design in shape and color. Standard gold shocks combine with newly developed medium soft (MS) front springs.
    Modern Servo Compatibility
    In place of the mini steering servo that was fixed with double-sided tape, the modern version of the ULTIMA uses a servo mount compatible with modern low-profile servos that are popular today. The shape of the servo saver arm has also been changed.
    Improved Clearance and Handling
    The front skid on the carbon chassis improves clearance over surface gaps while front caster angle setting optimizes handling characteristics.
    Exclusive Motor Guard
    Gunmetal anodized aluminum motor guard is laser-printed with the Kyosho 60th anniversary logo, which is exclusive to the special limited-edition model.
    Original JJ Specifications
    Polycarbonate rear wing and side plates have been recreated as per the original JJ specifications. The large side plates deliver improved stability to fully recreate the style and drive feeling of the original.
    • The 13th model of the Kyosho Vintage Series is a recreation of the World Champion racer that did not exist as a kit back in 1987
    • Each component has been faithfully designed and manufactured based on the specifications of the championship winning machine
    • While based on the original model, each part has been enhanced and modernized to meet the requirements of the latest RC systems and power sources
    • Body from the Tomahawk is included, which is as per the World Champion machine. Original as well as commemorative decals are also included
    • Turnbuckle tie rods allow precise adjustment of camber and toe angles, just like the original
    • Rear gearbox is equipped with ball differential that produces traction stability without affecting road grip
    • Rear drive incorporates a universal swing shaft that enables improved drive efficiency and maneuverability
    • Soft front and rear tires are included for racing performance. Inner sponges are also built into the front tires and deliver powerful grip and control
    • In addition to the standard type included in the kit, more modern 2.2-inch standard wheels can also be installed
    • Unassembled chassis kit includes wheels and tires for front and rear, unpainted body, and rear wing
    • Equipped with +2mm offset rear wheel hub. Wide tread setting is available when combined with the included 1mm spacers
    • Kyosho Ultima '87 JJ World Championship Replica 1/10 Scale 2WD Off-Road Buggy - KIT
    • Kit chassis
    • Unpainted body
    • Decals
    • 60th anniversary sticker
    • Hexagon wrench
    • Cross wrench
    • Shock wrench
    • Grease
    • Shock oil
    • Ball differential grease
    Requires:
    • 2-channel R/C system (1x servo and 1x ESC)
    • 540 Size Motor
    • ESC
    • Battery for chassis
    • Paint for polycarbonate body
    • Compatible battery charger - select a charger from our Charger Collection
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 1+ Hours
    Model Scale 1/10
    Length 405mm / 15.9in
    Width 250mm / 9.8in
    Height 172mm / 6.7in
    Weight (No Battery) 1,470g / 51.8oz
    Wheelbase 270mm / 10.6in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Carbon graphite
    Drivetrain 2WD
    Wheel Size (Diameter x Width) Front: 75x20mm / Rear: 82x36mm
    Wheel Hex Size N/A
    Tire Tread Front: 206mm / Rear: 214mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-Filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 8.64:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control Not Included
    Motor 540 Motor (required)
    Battery Not included
    Servos N/A
    Radio Not included
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
  • UnknownStranger
    • Nov 2023
    • 0
    Approach the murder mystery with a detective's mindset. Pay attention to details that may seem insignificant, as they how to organize a murder mystery party​ often become crucial clues. Develop a keen sense of observation, and don't dismiss anything as mere coincidence.
    • UnknownStranger
      • Nov 2023
      • 0
      But also serves as a functional element, providing visual cues or syncing with in-game events. The marriage of performance Why are headphones used? and aesthetics highlights the growing importance of personal expression in the world of computing.
