Official Kyosho Fazer Mk2 FZ02-D Turquoise 2006 Subaru Impreza 1/10 Scale 4WD Drift Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	kyosho-fazer-mk2-fz02-d-turquoise-2006-subaru-impreza-1-10-scale-4wd-drift-car-rtr.webp
    Version Info: This car is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.4V 5000mAh LiPo battery and a battery charger, purchased separately (see Requires below for details).
    For the pure enjoyment of R/C car driving, the combination of a beautifully reproduced car body with the FAZER series chassis can’t be beaten. Kyosho has taken its standard touring car chassis and given it a full model makeover that has evolved performance to a new level. A simplified design with fewer parts has improved maintenance efficiency and reduced weight while core strength and rigidity has been increased through new materials and ribbing and stiffeners on front and rear. In addition, the symmetrical chassis design synergizes excellent front-rear balance through the suspension with responsive control, irrespective of power source. Featuring slipper clutch, front & rear gear differentials, oil shocks and full ball bearing specs, the high durability and impact resistance allows drivers to unleash the full potential of the chassis. Brake disc wheel hubs with two different offsets (0mm, +5mm) provide compatibility with 190mm and 200mm width body styles and allows the wheelbase to be adjusted to 274mm by replacing some parts (sold separately) for compatibility with other 1/10 scale body styles, in addition the body included.
    The Readyset package comes fully assembled and includes everything except charger and battery for the chassis, batteries for the transmitter and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    New Chassis Design
    Completely new chassis realizes low center of gravity with its simple, functional design. Featuring an integrated gearbox that optimizes torsional rigidity of the main chassis, the nylon material reduces weight while improving impact resistance. Each key component has been reinforced in this simple design without upper deck.
    Reduced Screws and Parts
    Features a reduced number and variety of screws and parts, and consolidation of frequently used screws into the same size. Most screws are flat head screws that can be removed with a 2.0mm hex wrench for easy disassembly.
    Optimized Handling
    Handling factors such as bump steer and scrub radius are optimized on front suspension. Simple ball-connected steering knuckle promises reliable control movement. Interchangeable on both front and rear left-right hub carriers optimize spare parts utilization and improve maintenance efficiency.
    Two Offset Brake Disc Wheel Hubs
    Includes choice of two offset brake disc wheel hubs with dummy calipers (for visual styling) that provide compatibility with 190mm and 200mm body widths.
    New Design Oil Shocks
    New design oil shocks mark an evolutionary step up from previous models Oil shock is newly designed. Optimal front-rear geometry and balance simultaneously delivers both light handling and precise control. Equipped with long shock end allows a high ride height to pursue true scale appearance.
    Wide Range of Gear Ratio Settings
    Standard spur and pinion gear setting is 68T and 32T, but 9 pinion gear settings can be used from 29T – 37T to produce a wide range of gear ratio settings. The new fixed gear mesh motor mount has holes for use with each different pinion gears. Just simply mount the motor directly to the hole locations corresponding to the pinion gear. No gear mesh adjustment is necessary.
    • Pre-painted finished body with Kyosho's original coloring featuring beautiful gradation and flashy colors that are conscious of the drift scene
    • The number 60 is dispalyed on the side to commemorate the 60th anniversary of Kyosho
    • The resin drift tires that have both control performance and slide performance are equipped with 5-spoke racing wheels with deep rims
    • In the initial setting, the vehicle height is raised so that troubles due to gaps can be avoided
    • Factory-assembled Readyset package only requires 4 x AA alkaline batteries for the transmitter, and battery with charger for the chassis
    • Full ball bearings that reduce drive loss
    • Features KS202W steering servo
    • Sealed differential and transmission deliver reliable performance, even on dusty parking lot surfaces
    • Shaft drive full-time 4WD touring chassis
    • Equipped with a plated dummy brake disc and a painted brake caliper to improve the sense of scale
    • Uses Hex head button or countersunk screws within each part
    • Performance can be further enhanced by installing various optional parts
    • Kyosho Fazer Mk2 FZ02-D Turquoise 2006 Subaru Impreza 1/10 Scale 4WD Drift Car - RTR
    • Completed chassis with R/C radio installed
    • Factory assembled body complete with color scheme
    • Syncro KT-231P+ transmitter
    • Hex wrenches
    • Spanner
    • Setting change parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/10
    Length 456mm / 17.9in
    Width 200mm / 7.8in
    Height 140mm / 5.5in
    Weight (No Battery) 1650g / 58.2oz
    Wheelbase 260mm / 10.2in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 63.2mm x 24.2mm
    Wheel Hex Size N/A
    Tire Tread 174mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 6.54:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor 550 size 14T brushed motor (G14L)
    Battery 4x AA alkaline and 1x 7.4V 4000-5000mAh LiPo battery (required)
    Servos N/A
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
