Official Kyosho Fazer Mk2 FZ02-R Subaru Impreza WRC2002 1/10 Scale 4WD Rally Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	kyosho-fazer-mk2-fz-02r-subaru-impreza-wrc2002-1-10-scale-4wd-rally-car-rtr-motion-rc-35054099824825.webp
    Version Info: This car is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.4V 5000mAh LiPo battery and a battery charger, purchased separately (see Requires below for details).
    In the world of 1/10 EP (electric) models, the booming popularity of the FAZER Mk2 is driven by the combination of its exceptional performance and handling, whether for beginners with the pre-assembled Readyset or the easy to assemble kit. Now the FAZER Mk2 adds a rally weapon in the form of the FZ02-R to its lineup.
    The suspension system is the foundation of rally performance, and the FZ02-R features front and rear shock stays developed to support oil shocks with newly designed pistons and cases that deliver plenty of suspension stroke and exceptional running performance both on road and over the roughest surfaces. Shaft-type 4WD produces superior traction control and works optimally with new rally tires to transfer motor power efficiently to the road surface. Front bumper skid protects the front part of the chassis from impact before and after jumps, and a chassis cover protects the R/C units from dirt, sand, and stones.
    Included in the kit is Kyosho’s ultra-scale body reproduction of the Subaru Impreza WRC2002 made famous by Tommi Mäkinen in winning the first round Rally Monte Carlo four times in a row. An optional LED light unit recreated using the actual design data and materials of the original vehicle can also be attached to the body. This easy to finish Readyset features Subaru’s signature blue tone with 6-star logo and 15-spoke gold wheels to recreate the performance and experience of Subaru’s golden age of rally dominance in full throttle.
    The Readyset package comes fully assembled and includes everything except charger and battery for the chassis, batteries for the transmitter and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Ultra Scale Body
    Includes Subaru Impreza WRC2002 body complete with colorful 6-star graphic and decals. Accessory parts unique to the ultra-scale body recreate the image of the original car in all its glory.
    New Chassis Design
    Fazer Mk2 FZ02-R chassis has been specially developed for rally models. The 4WD system produces exceptional control and reliability, ideal for both on and off-road rally driving.
    New Rally Tires
    Block pattern tires deliver high grip from asphalt to dirt and combine with gold spoke wheels to elevate style in line with performance.
    Chassis Cover
    Includes a chassis cover to protect the sensitive RC equipment from dirt and other elements is included as a standard feature.
    New Design Oil Shocks
    Features oil shocks with big bore cases and pistons designed for hard-core off-road driving. Newly developed springs reproduce true rally car driving characteristics.
    Wide Range of Gear Ratio Settings
    Comes equipped with a sintered 32T pinion gear that exhibits outstanding durability even during high-load off-road driving. The motor mount, which requires no backlash adjustment, allows compatibility with pinion gears ranging from 29T to 37T.
    • Readyset includes fully assembled chassis and body with pistol-grip transmitter
    • Ultra-scale Impreza WRC2002 body captures the heart and soul of rally driving
    • Includes two types of wheel hubs with different offsets so tread can be changed according to the body width
    • Shaft 4WD system produces exceptional control and reliability
    • Suspension system features newly designed shock case, piston, shock stay, and front bumper
    • Completely sealed gearboxes are equipped with proven bevel-type differential gears on front and rear
    • Equipped with chassis cover that protects the RC units and drive system from dirt and other elements
    • Features full ball bearing specifications for optimal drive efficiency
    • Hex head socket screws enable easy and efficient maintenance
    • Syncro KT-231P+ pistol-grip transmitter included and provides various setting options
    • Compatible with existing FAZER Mk2 optional parts so you can enjoy tuning and upgrading your machine
    • Kyosho Fazer Mk2 FZ02-R Subaru Impreza WRC2002 1/10 Scale 4WD Rally Car - RTR
    • Completed chassis with RC radio installed
    • Factory assembled body complete with color scheme
    • Syncro KT-231P+ transmitter
    • Hex wrenche
    • Spanner
    • Setting change parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/10
    Length 464mm / 18.2in
    Width 206mm / 8.1in
    Height 154mm / 6.0in
    Weight (No Battery) 1650g / 58.2oz
    Wheelbase 260mm / 10.2in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis FZ02-R
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 70mm x 27mm
    Wheel Hex Size N/A
    Tire Tread 174mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 6.54:1
    Final Drive Ratio N/A
    Pinion 32T (adjustable 29T-37T)
    Spur Gear N/A
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor 550 size 14T brushed motor (G14L)
    Battery 4x AA alkaline and 1x 7.4V 4000-5000mAh LiPo battery (required)
    Servos N/A
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
