Official Kyosho Fazer Mk2 FZ02 2020 Mercedes-AMG GT3 "50 Years Legend of Spa" 1/10 Scale 4WD Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	kyosho-fazer-mk2-fz02-2020-mercedes-amg-gt3-50-years-legend-of-spa-1-10-scale-4wd-car-rtr-motion-rc-35055397732537.webp
    Version Info: This car is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.4V 5000mAh LiPo battery and a battery charger, purchased separately (see Requires below for details).
    For the pure enjoyment of R/C car driving, the combination of a beautifully reproduced car body with the FAZER series chassis can’t be beaten. Kyosho has taken its standard touring car chassis and given it a full model makeover that has evolved performance to a new level. A simplified design with fewer parts has improved maintenance efficiency and reduced weight while core strength and rigidity has been increased through new materials and ribbing and stiffeners on front and rear. In addition, the symmetrical chassis design synergizes excellent front-rear balance through the suspension with responsive control, irrespective of power source.
    Featuring front & rear gear differentials, oil shocks and full ball bearing specs, the high durability and impact resistance allows drivers to unleash the full potential of the chassis. Brake disc wheel hubs with two different offsets (0mm, +5mm) provide compatibility with 190mm and 200mm width body styles and allows the wheelbase to be adjusted to 260mm by replacing some parts (sold separately) for compatibility with other 1/10 scale body styles, in addition the body included.
    The Readyset package comes fully assembled and includes everything except charger and battery for the chassis, batteries for the transmitter and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    New Chassis Design
    Completely new chassis realizes low center of gravity with its simple, functional design. Featuring an integrated gearbox that optimizes torsional rigidity of the main chassis, the nylon material reduces weight while improving impact resistance. Each key component has been reinforced in this simple design without upper deck.
    Scale Tires
    Original low-profile semi-slick pattern tires produce superior performance.
    Optimized Handling
    Handling factors such as bump steer and scrub radius are optimized on front suspension. Simple ball-connected steering knuckle promises reliable control movement. Interchangeable on both front and rear left-right hub carriers optimize spare parts utilization and improve maintenance efficiency.
    Two Offset Brake Disc Wheel Hubs
    Includes choice of two offset brake disc wheel hubs with dummy calipers (for visual styling) that provide compatibility with 190mm and 200mm body widths.
    New Design Oil Shocks
    New design oil shocks mark an evolutionary step up from previous models Oil shock is newly designed. Optimal front-rear geometry and balance simultaneously delivers both light handling and precise control. Equipped with long shock end allows a high ride height to pursue true scale appearance.
    Wide Range of Gear Ratio Settings
    Standard spur and pinion gear setting is 68T and 32T, but 9 pinion gear settings can be used from 29T – 37T to produce a wide range of gear ratio settings. The new fixed gear mesh motor mount has holes for use with each different pinion gears. Just simply mount the motor directly to the hole locations corresponding to the pinion gear. No gear mesh adjustment is necessary.
    • “Ultra Scale Body” replicates the fine details of the actual body of the car.
    • Low-profile semi-slick pattern tires produce superior performance
    • Factory-assembled Readyset package only requires 4 x AA alkaline batteries for the transmitter, and battery with charger for the chassis
    • Full ball bearings that reduce drive loss equipped throughout the drive system
    • Features KS202W steering servo
    • Includes completely finished body with color scheme and decals applied
    • Sealed differential and transmission deliver reliable performance, even on dusty parking lot surfaces
    • Uses button screws with hexagonal holes in each part. Reliable tightening torque can be applied, and maintenance is possible with even fewer tools
    • Performance can be further enhanced by installing various optional parts
    • Kyosho Fazer Mk2 FZ02 2020 Mercedes-AMG GT3 "50 Years Legend of Spa" 1/10 Scale 4WD Car - RTR
    • Completed chassis with RC radio installed
    • Factory assembled body complete with color scheme
    • Syncro KT-231P+ transmitter
    • Setting change parts
    • Hex wrenche
    • Spanner
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/10
    Length 464mm / 18.2in
    Width 207mm / 8.1in
    Height 126mm / 4.9in
    Weight (No Battery) 1650g / 58.2oz
    Wheelbase 260mm / 10.2in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis FZ02
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 66mm x 25mm
    Wheel Hex Size N/A
    Tire Tread 174mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 6.54:1
    Final Drive Ratio N/A
    Pinion 32T (adjustable 29T-37T)
    Spur Gear 68T
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor 550 size 14T brushed motor (G14L)
    Battery 4x AA alkaline and 1x 7.4V 4000-5000mAh LiPo battery (required)
    Servos KS202W steering servo
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
