Official Kyosho Inferno NEO 3.0 ReadySet 1/8 Scale 4WD Nitro Buggy Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	kyosho-inferno-neo-3-0-readyset-red-1-8-scale-4wd-nitro-buggy-rtr-motion-rc-35055579201721.webp
Name:	kyosho-inferno-neo-3-0-readyset-yellow-1-8-scale-4wd-nitro-buggy-rtr-motion-rc-35055606104249.webp
    Version Info: This truck is delivered as "RTR", however does require 8x AA batteries for the transmitter and receiver, also you will need a fuel bottle, glow igniter and fuel, purchased separately (see Requires below for details).
    With 8 World Championship titles, the ‘Inferno’ is proud to be KYOSHO’s flagship model. Infused with Inferno DNA, the Inferno NEO 3.0 is ready to race almost as soon as it’s out of the box and brings the Inferno’s glorious performance potential within reach of everyone. While excelling on racing circuits, the NEO 3.0 also runs through rough terrain like a boss with features such as the user-friendly KE21SP engine with recoil pull starter and Big Bore Shocks with the KC Cross Tires that deliver an optimal balance of performance and traction on any surface. Based on the competition-level chassis, the NEO 3.0 promises exceptional reliability and durability plus a wide range of setting adjustments and custom performance upgrades through the huge range of optional parts available for the MP7.5 series. Experiencing the thrill of engine-powered off-road buggy racing has been made easy with the Inferno NEO 3.0 and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    New KE21SP Engine
    The new KE21SP engine delivers an optimal balance of power, torque, idling stability and easy starting. Features rear exit exhaust, recoil starter and slide carburetor.Engine break-in is made effective and easy even for beginners with the inclusion of reducer for break-in.
    Excellent Shock Absorption
    Aluminum big bore shocks on front and rear feature dial spring adjustment and deliver excellent shock absorption and superior running stability under any situation. Sway bars are also included on the front and rear.
    Improved Steering Response and Stability
    Long type front suspension arms deliver improved steering response and stability. Turnbuckle tie rods allow for precision adjustment of camber and toe.
    Balanced Performance
    Cab forward body delivers balanced performance between steering response and traction.
    • ReadySet includes pre-assembled chassis installed with engine and R/C components as well as finished body
    • Chassis belongs to the Inferno series with its unrivalled record of racing success including world championship titles
    • Shaft-driven 4WD system delivers high traction performance even on low-grip road surfaces
    • 3-differential system with front, rear and center drive units, produces exceptional drive stability
    • Front wheels equipped with universal swing shafts that efficiently transfer power with excellent reliability
    • Double disc brake delivers reliable braking power
    • Equipped with KE21SP engine fitted with recoil starter for easy starting
    • Includes easy-to-use pistol-grip Syncro KT-231P+ transmitter
    • Receiver features a fail-safe function in case of radio signal interference
    • New KS5071-09MW servos incorporating metal gears produce high torque for superior responsiveness even in hard driving
    • Kyosho Inferno NEO 3.0 ReadySet Red 1/8 Scale 4WD Nitro Buggy - RTR
    • Factory assembled chassis complete with control linkages
    • Finished body complete with printed color scheme
    • 2.4GHz Syncro KT-231P+ transmitter
    • 1.5, 2.0, 2.5, 3.0mm L shaped hex wrenches
    • Cross wrench
    • 17mm wheel wrench
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 15 Minutes
    Model Scale 1/8
    Length 469mm / 18.4in
    Width 307mm / 12.0in
    Height 189mm / 7.4in
    Weight (No Battery) 3400g / 119.9oz
    Wheelbase 325.5mm / 12.8in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 116mm x 44mm
    Wheel Hex Size 17mm
    Tire Tread 258mm / 261mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 11.56:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes Disc
    Electronic Speed Control N/A
    Engine KE21SP
    Battery 8x AA batteries (required)
    Servos KS5071-09MW
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 15 minutes
    Recommended Environment Offroad
  • NoseHonker
    • Jan 2024
    For the new 2024 versions (the red and yellow body colors), can anyone confirm if there are any mechanical differences from the prior versions? 2 items specifically:
    1. Are the differentials built with 2 planetary gears or 4? Prior versions were built with 2 and grease-filled, not oil, which worked but required a rebuild to tune and strengthen.
    2. Are front and rear anti-roll bars included on this version? They were not on prior versions and had to be purchased separately. I've seen conflicting information about whether they come installed or not on the current version.
    3. Any other mechanical changes from the previous versions other than the new cosmetic body graphic schemes?
    Thanks!
    • jbaartz
      • Sep 2020
      • 488
      Thanks!
      1. They have the same setup; 2 spider gears.
      2. The sway bars are not included and have to be purchased separately. The part numbers are IFW104B and IF117.
      3. There are no other mechanical changes from the previous versions.
      • NoseHonker
        • Jan 2024
        Thank you for the quick reply and confirmation, much appreciated!
