Official Kyosho Mini-Z Inferno MP9 1/27 Scale 4WD Buggy Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	kyosho-mini-z-blue-yellow-inferno-mp9-1-27-scale-4wd-buggy-rtr-motion-rc-35314272239801.webp
Name:	kyosho-mini-z-pink-green-inferno-mp9-1-27-scale-4wd-buggy-rtr-motion-rc-35314289868985.webp
    Version Info: This buggy is delivered as "RTR", however does require 4x AAA batteries for the transmitter and 4x AAA batteries for the chassis, purchased separately (see Requires below for details).
    Simply add eight AAA-size alkaline batteries to this Readyset and the MINI-Z Buggy brings the fun of R/C car action. The advanced compact design includes 4WD drive train with slipper clutch to protect the gear system, and 4-wheel independent double wishbone suspension with oil-filled shocks to deliver true racing buggy performance. Most critical components are protected within the high-rigidity dustproof chassis shell.
    7-stage geared steering servo provides plenty of torque for precision steering response and combines with the control program to deliver the MINI-Z’s signature linear handling and light feel. The circuit board also features manual volume adjustment for the optional gyro unit (sold separately) that stabilizes straight line running and improves cornering control.
    Modeled on the popular Inferno MP9, the MINI-Z buggy body matches performance with style featuring a distinctive new printed color scheme complimented by black wheels for the sharpest looking machine on the track. The fully pre-assembled Readyset package makes it simple and enjoyable for anyone to experience advanced R/C buggy performance, whether it’s your first car or as fun-driving second car.
    Your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    4-Wheel Independent Suspension
    Shaft driven 4WD and 4-wheel independent suspension are condensed in the MINI-Z’s compact size. The chassis powers easily over small bumps and gaps.
    Main Part Protection
    Main parts including sealed diff gearbox are contained within the dust resistant structure. 15 ball bearings and a slipper clutch make this machine ready for serious action.
    Surefooted Handling
    4-wheel independent double wishbone suspension equipped with oil shocks. Delivers surefooted road holding over a variety of different road surface conditions.
    Low CG, Balanced Handling
    Chassis features shell structure with battery boxes on each side for low CG and balanced handling. High rigidity extracts full effectiveness from the suspension.
    • Readyset package allows the model to be enjoyed straight after purchasing batteries
    • Fully pre-assembled chassis with printed polycarbonate body
    • Real racing performance will please buggy owners, and it's great for indoor practice
    • Includes Syncro KT-531P transmitter, and allows various setting adjustments such as steering angle
    • The FHSS 2.4GHz R/C system removes the need to manage frequency bands
    • Most optional parts already released for MINI-Z buggies can be installed
    • Kyosho Mini-Z Blue/Yellow Inferno MP9 1/27 Scale 4WD Buggy - RTR
    • Factory assembled chassis with pre-installed R/C unit
    • KT-531P transmitter
    • Pre-painted polycarbonate body finished with markings
    • Pinion gears 11T, 13T, 15T and tool
    • Spur gears 33T, 35T
    • Pairing stick
    • Spare wheel nuts and wrench
    AGE LEVEL : 11 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/27
    Length 167mm / 6.5in
    Width 106mm / 4.1in
    Height 68mm / 2.6in
    Weight (No Battery) 200g / 7.0oz
    Wheelbase 115mm / 4.5in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis Buggy
    Drivetrain 4WD
    Wheel Hex Size N/A
    Tire Tread 89mm
    Bushing Material N/A
    Suspension Independent
    Shock Type Oil-filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 11T, 13T, 15T
    Spur Gear 33T, 35T
    Differential N/A
    Ball Bearings 15
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Outdoors, smooth to rugged surfaces
  • JaniceBowers
    • May 2024
    • 3
    Physical demands and intensity levels vary between pickleball and tennis. Tennis generally requires more stamina and endurance due to official pickleball rules​ the larger court and longer rallies, while pickleball is less physically demanding.​
    • JaniceBowers
      • May 2024
      • 3
      Navigating through large volumes of customer data is streamlined with advanced search and filtering capabilities. Product managers can best small business management software​ quickly find relevant information needed for decision-making.​
      • kendrey14
        • Nov 2024
        • 3
        Cool RC. Link.
        • kendrey14
          • Nov 2024
          • 3
          I just want to ask where I can buy this kind of RC model. Anyone? stucco repair near me
          • kendrey14
            • Nov 2024
            • 3
            Stucco is a strong, versatile material used on walls to give your home a textured and attractive finish while also providing protection. For the best maintenance and repair services for your stucco, rely on Stucco Repair Daytona Beach for top-notch results. stucco companies Daytona Beach​.
