Official Kyosho Mini-Z Honda NZX MR-03 1/27 Scale RWD Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	Mini-Z White Honda NZX MR-03.webp Views:	0 Size:	27.9 KB ID:	406407
    Click image for larger version  Name:	Mini-Z Red Honda NZX MR-03.webp Views:	0 Size:	31.2 KB ID:	406408
    With just 8 x AAA-size batteries, the MINI-Z Racer allows anyone to enjoy the beautiful style and advanced performance of R/C cars. First launched in 2013, Kyosho has renewed the MINI-Z Racer Sports MR-03 concept to be even more user-friendly and appealing to more drivers with the MINI-Z RWD series! Widely popular body styles in highly detailed body sets create the incredibly realistic model lineup. Including the latest Syncro KT-531P transmitter with steering trim, throttle trim, dual rate, LED control function, the sponge grip of the steering wheel provides comfortable fit for precision control feel.
    The set also includes a car body finished to display-model standard that matches stunning style with the performance, reliability and durability of the MR-03 chassis. The control program on the newly designed circuit board produces linear handling characteristics and can be further enhanced for even easier control by installing the optional gyro unit (MZW446). This series represents the perfect package for a deep dive into the amazing world of R/C cars and is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    KT-531P Transmitter
    Includes stylish Syncro KT-531P transmitter. Features steering / throttle trim as well as steering dual rate adjustment and LED control function.The transmitter also has a Training Mode feature which limits speed of the car for easy learning (Default setting at the time of shipment is Training Mode).
    Gyro Compatibility
    Narrow or Wide Tread
    Can be set to either narrow or wide tread by replacing the front lower and upper plates and steering tie rod. Of course the wheelbase can still be adjusted to suit certain body types. (*Wheelbase change requires optional parts).
    Upgrade to Fit Your Needs
    Compatible with a huge lineup of optional parts for the MR-03 chassis that allows you to improve your machine according to your skill level and budget.
    Highly Detailed
    The highly detailed display-standard body is fully factory finished.
    • New series includes the newly developed Syncro KT-531P transmitter with multiple setting options
    • New circuit board with newly developed control program realizes dramatically improved steering feel
    • Highly detailed display-standard body is fully factory finished
    • Full ball bearing specifications include 7 bearings, previously an optional upgrade.
    • Compatible with all MINI-Z Racer body styles. **Motor case and diff gear assembly to suit body are required to be purchased separately
    • Front suspension incorporates VCS that optimizes camber angle with suspension stroke
    • Compatible with optional gyro unit (MZW446); the volume of gyro effect can be adjusted on the chassis
    • Kyosho Mini-Z White Honda NZX MR-03 1/27 Scale RWD Car - RTR
    • Factory assembled chassis
    • Pre-painted plastic body, complete with markings
    • 2.4GHz Perfex KT-531P 2.4GHz transmitter
    • Front tread adjustment parts set
    • Front suspension adjustment spacers
    • Pinion gears 6T, 7T, 8T, 9T
    • Wheel wrench
    • Pinion gear tool
    • Spare nuts
    • Pairing stick
    • Tires, wheels
    AGE LEVEL : 11 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/27
    Length 168mm / 6.6in
    Width 73mm / 2.9in
    Height 44.5mm / 1.75in
    Weight (No Battery) 130g / 4.6oz
    Wheelbase 99mm / 3.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis MR-03
    Drivetrain RWD
    Wheel Hex Size N/A
    Tire Tread F: 59.5mm R: 57mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 6T, 7T, 8T, 9T
    Spur Gear N/A
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
