Official FMS FCX24M Land Rover Camel Trophy Edition 1/24 Scale 4WD Crawler Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	fms-fcx24m-land-rover-discovery-camel-trophy-edition-1-24-scale-4wd-crawler-rtr.webp
Name:	fms-fcx24m-land-rover-defender-90-camel-trophy-edition-1-24-scale-4wd-crawler-rtr-motion-rc-35839060279481.webp
Name:	fms-fcx24m-land-rover-defender-110-camel-trophy-edition-1-24-scale-4wd-crawler-rtr-motion-rc-35838630887609.webp
    Version Info: This truck is delivered as "RTR", however does require 4 x AAA batteries for the transmitter sold separately (see Requires below for details).
    Introducing the officially licensed FMS 1/24 scale FCX24M Land Rover Family RC cars. These models feature the newly developed FCX24M realistic crawling chassis and meticulously crafted hard-shell bodies, faithfully replicating the iconic appearance and off-road performance of the first-generation Range Rover, Discovery, Defender 90, and Defender 110, as seen in the legendary Camel Trophy competitions. Relive the epic history of these classic vehicles with the Land Rover RC family.
    The Camel Trophy, held between 1980 and 2000, was a unique adventure event focused on endurance rather than speed. It tested the resilience of participants and their vehicles under extreme conditions, earning the nickname 'The Olympics of 4x4.' Sponsored by Land Rover, the event featured vehicles like the Range Rover, Defender 90, Defender 110, and Discovery, all painted in distinctive Sandglow Yellow. These Land Rovers tackled some of the world's most challenging terrains, creating legendary off-road stories. Now, you can revive the Camel Trophy spirit with the FCX24M Land Rover!
    To capture the essence of Land Rover's Camel Trophy in 1/24 scale, these models use ABS hard plastic car casings to accurately reproduce vehicle details and body colors. Each model comes with its own roof rack, which can be optionally equipped with scale parts like fuel drums, spare tires, equipment boxes, and recovery boards, allowing you to fully immerse yourself in the spirit and history of the Camel Trophy.
    The FCX24M stands out as one of the only 1/24 scale crawler cars on the market with a factory-installed two-speed transmission. This feature offers an unprecedented level of fun compared to traditional small-scale crawlers. The standard two-speed transmission in the FCX24M series delivers an exciting blend of low-speed high-torque crawling and high-speed gear thrills, providing an exhilarating off-road control experience.
    A Tribute to Camel Trophy History
    Officially licensed by Land Rover with the distinctive Camel Trophy "Sandglow" color scheme.
    Quick-Detatch Body
    The hinged quick-detach design enables fast removal of the body within seconds, facilitating easy battery changes, maintenance of parts, and upgrades to accessories whenever needed.
    Counter-Rotating Driveshafts
    Counter-rotating driveshafts effectively minimize axle torque twist, improving off-road crawling performance.
    Metal C-Channel Chassis Rails
    The metal frame chassis, crafted from robust materials, combined with high-strength nylon links, provides a solid foundation for conquering more challenging terrains.
    Metal Gears
    The vehicle features metal bevel gears in both the front and rear axles, along with a full complement of metal ball bearings, providing a smooth, stable, and reliable transmission.
    Crawling Tires
    Utilizing softer rubber tires with single stage foams provides exceptional crawling capabilities when navigating diverse terrains such as muddy paths, carpets, grassy fields, and sidewalks.
    • Licensed by Jaguar Land Rover Limited
    • New generation FCX24M chassis
    • Non-bearing trapezoidal metal beam
    • ABS hard body
    • Fully simulated interior with exquisite details
    • Two-speed transmission, enabling off-roading and crawling
    • Large-diameter tires provide sufficient ground clearance
    • Factory-installed roof rack
    • FMS FCX24M Land Rover Discovery Camel Trophy Edition 1/24 Scale 4WD Crawler - RTR
    • G3 V3 transmitter
    • 2-in-1 R3A receiver / ESC (installed)
    • 050 brushed motor (installed)
    • Steering servo (installed)
    • 7.4V 380mAh LiPo battery
    • USB battery charger
    • Tool bag
    • Product manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/24
    Length 232mm / 9.1in
    Width 105mm / 4.1in
    Height 133mm / 5.2in
    Weight (No Battery) N/A
    Wheelbase 134mm / 5.2in
    Ground Clearance 28mm / 1.1in
    Body ABS Plastic, factory painted and decorated
    Chassis Composite with metal C-channel rails
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 48mm x 17mm
    Wheel Hex Size N/A
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension Four-link front and rear
    Shock Type Oil-filled
    Transmission 2-speed
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control 2-in-1 RX/ESC
    Motor 050 brushed motor
    Battery 2S 7.4V 380mAh LiPo
    Servos 1
    Radio G3 V3 transmitter (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Indoors/Outdoors
