Official Carisma M40S Subaru BRZ GT300 1/10 Scale Brushless 4WD Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: Although fully assembled, decorated, and ready-to-run, this model requires a 7.4V 2S Lipo battery and suitable charger, along with 4 AA alkaline batteries for the transmitter.
    Now available from Motion RC, Carisma’s stunning new 1/10 scale replica of the Subaru BRZ GT300 racer that competes in the Japanese Super GT Series. This impressive 4WD platform is powered by a maintenance-free, 2400kV brushless motor and a versatile, 3S-capable ARC-3 electronic speed control. Although capable of outstanding performance, this model arrives so carefully painted and expertly detailed that you may hesitate to get it dirty and instead consider it as a display model. The officially licensed Subaru BRZ polycarbonate body includes rear wing, diffuser, front splitter, and mirrors as well as all sponsor graphics from the 1:1 scale race car that competed in the 2021 season.
    The Carisma CTX-2000 2.4GHz radio system features steering rate adjustment, steering and throttle trims, servo reversing and uses F.H.S.S (Frequency Hopping Spread Spectrum) technology for interference-free control.
    Enjoy an impressive driving experience by combining the versatile, on road fun of Carisma’s M40S Subaru BRZ GT300 1/10 Scale Brushless 4WD Car with Motion RC’s industry-leading customer service and product selection for a package that cannot be beat!
    Complete Package
    The Carisma M40S BRZ arrives assembled, decorated, and ready to run. Install your choice of 2S Lipo or 6-cell NiMH battery power and its race-ready!
    Smooth Operator
    The smooth underside of the composite chassis allows for minimal ride height without concern for any chassis or suspension component scraping the tarmac.
    Scale Detail
    The rear wing and diffuser along with the functional front splitter combine to create a scale masterpiece suitable for a bookshelf or mantle.
    Sealed Drivetrain
    The M40S platform features a logical, easy-to-maintain equipment layout with sealed diffs and gear covers to eliminate damage from small stones or other debris.
    • Officially licensed Subaru BRZ body and graphics
    • Shaft-driven 4WD System
    • Reliable and responsive 2.4GHz radio gear
    • 3Kg metal-geared steering servo
    • ARC-3 brushless ESC
    • Oil-filled, coil-over adjustable composite shocks
    • Complete ball bearings
    • 2400kV vrushless motor
    • F/R gear differentials
    • Carisma M40S Subaru BRZ GT300 1/10 Scale Brushless 4WD Car - RTR
    • Carisma CTX-2000 2.4GHz transmitter
    • Instruction manual
    • Extra differential gears and ride height adjusters
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 30 Minutes
    Model Scale 1/10
    Length 435mm / 17.1in
    Width 189mm / 7.4in
    Height 115mm / 4.5in
    Weight (No Battery) 1550g / 54.6oz
    Wheelbase 257mm / 10.1in
    Ground Clearance 7mm / 0.27in
    Body Polycarbonate, factory painted and decorated
    Chassis Composite
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 60 x 24mm
    Wheel Hex Size 12mm
    Tire Tread Slicks
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Oil-filled, coil-over, adjustable
    Transmission Direct drive
    Gear Pitch MOD 05
    Internal Gear Ratio 2.6:1
    Final Drive Ratio 9.36:1
    Pinion 20T
    Spur Gear 72T
    Differential Grease-filled F/R differentials
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control AARC-3 ESC, 35A with XT60 Connector
    Motor 2400kV brushless
    Battery 2-3S with XT60 connector (required)
    Max Battery Dimensions (L x W x H) 135mm x 50mm x 30mm
    Servos Waterproof, metal gear, 3kg
    Radio 2-channel (included)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time Less than 30 minutes
  • fatboycamaro69
    • Dec 2024
    Has anyone ran this car on 3s? I can't find a good review on this car, anyone have anything to offer?
    Thanks in advance. Henry
