Official Kyosho Fazer MK2 FZ02-R 1971 Datsun 240Z Rally 1/10 Scale 4WD Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: This car is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.4V 5000mAh LiPo battery and a battery charger, purchased separately (see Requires below for details).
    In the world of 1/10 EP (electric) models, the booming popularity of the FAZER Mk2 is driven by the combination of its exceptional performance and handling, whether for beginners with the pre-assembled Readyset or the easy to assemble kit. Now the FAZER Mk2 adds a rally weapon in the form of the FZ02-R to its lineup.
    The suspension system is the foundation of rally performance, and the FZ02-R features front and rear shock stays developed to support oil shocks with pistons and cases designed for rally use provide sufficient suspension stroke and excellent performance even on paved roads or the roughest surfaces. Shaft-type 4WD produces superior traction control and works optimally with vintage tires efficiently transfer motor power to the road surface. Front bumper skid protects the front part of the chassis from impact before and after jumps, and a chassis cover protects the RC units from dirt, sand, and stones.
    The body included in the kit faithfully reproduces the rally specifications of a Nissan (exported as Datsun) sports car that made its debut in the 1971 East African Safari Rally, where it remarkably clinched the overall victory despite being a newcomer, known for its harsh conditions. This body, crafted uniquely by Kyosho in an ultra-scale form, was meticulously sculpted based on data and materials from the actual vehicle. Additionally, it is possible to attach a separately sold LED light unit to the body.
    The Readyset package comes fully assembled and includes everything except charger and battery for the chassis, batteries for the transmitter and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Ultra Scale Body
    The headlights, rear combination lamps, mirrors, etc. are reproduced using injection parts, and new molds are created for the front and rear fog lamps. The light buckets are compatible with separately sold LED light units, resulting in a more scaled appearance when installed.
    Wide Range of Gear Ratio Settings
    Comes equipped with a sintered 32T pinion gear that exhibits outstanding durability even during high-load off-road driving. The motor mount, which requires no backlash adjustment, allows compatibility with pinion gears ranging from 29T to 37T.
    New Chassis Design
    Fazer Mk2 FZ02-R chassis has been specially developed for rally models. The 4WD system produces exceptional control and reliability, ideal for both on and off-road rally driving.
    New Rally Tires
    New vintage rally tires to enhance the scale realism of vintage rally cars.
    New Design Oil Shocks
    Features oil shocks with big bore cases and pistons designed for hard-core off-road driving. Newly developed springs reproduce true rally car driving characteristics.
    Chassis Cover
    Includes a chassis cover to protect the sensitive RC equipment from dirt and other elements is included as a standard feature.
    • Readyset includes fully assembled chassis and body with pistol-grip transmitter
    • Ultra-scale 1971 DATSUN 240Z Rally body captures the heart and soul of rally driving
    • Includes two types of wheel hubs with different offsets so tread can be changed according to the body width
    • Shaft 4WD system produces exceptional control and reliability
    • Shock case, piston, shock stay and front bumper designed specifically for rally style driving
    • Completely sealed gearboxes are equipped with proven bevel-type differential gears on front and rear
    • Equipped with chassis cover that protects the RC units and drive system from dirt and other elements
    • Features full ball bearing specifications for optimal drive efficiency
    • Hex socket screws enable easy and efficient maintenance
    • Syncro KT-231P+ pistol-grip transmitter included and provides various setting options
    • Compatible with existing FAZER Mk2 optional parts so you can enjoy tuning and upgrading your machine
    • Add your own batteries for chassis, transmitter and battery charger, and you are ready to run!
    • Kyosho Fazer MK2 FZ02-R 1971 Datsun 240Z Rally 1/10 Scale 4WD Car - RTR
    • Completed chassis with RC radio installed
    • Factory assembled body complete with color scheme
    • Syncro KT-231P+ transmitter
    • Hex wrench
    • Spanner
    • Setting change parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/10
    Length 473mm / 18.6in
    Width 194mm / 7.6in
    Height 142mm / 5.6in
    Weight (No Battery) 1650g / 58.2oz
    Wheelbase 260mm / 10.2in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis FZ02-R
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 70mm x 28mm
    Wheel Hex Size N/A
    Tire Tread 167mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 32T (adjustable 29T-37T)
    Spur Gear N/A
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor 550 size 14T brushed motor (G14L)
    Battery 4x AA alkaline and 1x 7.4V 4000-5000mAh LiPo battery (required)
    Servos N/A
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
