Official Kyosho Mini-Z Porsche 911 GT3 RS MR-04 1/27 Scale RWD Car Discussion Thread
  • L Miller
    • Aug 2025
    • 4
    Mini-Z Lava Orange Porsche 911 GT3 RS MR-04 1/27 Scale RWD Car - RTR from Kyosho - KYO32358OR
    Enjoy the full experience of high-performance RC car racing right out of the box; just insert batteries into the car and transmitter. This is the simplicity of Kyosho Readyset packages. The small scale of the MINI-Z Racer is ideal for driving indoors and for people just becoming familiar with RC cars. This MINI-Z RWD Readyset includes a renewed 2-wheel drive chassis at its core. Previous Readyset packages incorporated the 3rd generation MR-03 chassis, but the new RWD Readyset includes the 4th generation MR-04 chassis that was first released in 2023.
    While retaining some basic elements of the MR-03 design, the new MR-04 demonstrated its lower center of gravity and remodeled steering design with blistering speed and excellent handling in the top-of-the-line EVO2 debut model. The MR-04 chassis is mounted with RC system and features a completed body finished to display model standard. This Readyset includes the same standard MR-04 chassis as other high-end MR-04 models and includes user-friendly 130-class brushed motor and the reliable Syncro KT-531P pistol grip transmitter. Just insert 4 x AAA alkaline batteries into both the car and the transmitter, and you’re ready for the fun to begin. High-performance comes straight from the standard setup, but you can tune up for elite-level performance with a wide range of MINI-Z optional parts. With its dynamic maneuverability, and display model finish, the updated MR-04 chassis takes the authentic RC experience to a higher level and your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    A New Chassis
    While retaining the best aspects of the MR-03, the lower center of gravity of the new MR-04 delivers significant performance improvements. The easier control of the MR-04 makes it an ideal introduction to RC cars.
    KT-531P Transmitter
    Includes stylish Syncro KT-531P transmitter. Features steering / throttle trim as well as steering dual rate adjustment and LED control function.The transmitter also has a Training Mode feature which limits speed of the car for easy learning (Default setting at the time of shipment is Training Mode).
    Improved Steering
    Front suspension dynamically aligns the camber angle with movement of the upper arm to maintain optimal tire contact during cornering. Revised caster angle also delivers improved steering response.
    Full Ball Bearings
    All axles are equipped with low rotational resistance ball bearings as standard. The same size ball bearings are used for both front and rear for spare parts efficiency.
    • Authentic EP (electric) small scale RC car that can be driven indoors
    • Readyset package includes fully assembled chassis, body and transmitter
    • Includes ultra reliable multi-function Syncro KT-531P transmitter
    • Features the MR-04 chassis, a major evolution from the previous MR-03 model
    • Includes high-quality painted body with decals applied, finished to display model standard
    • Compatible with all bodies for the MINI-Z racer series. *Motor case and differential gear assembly suitable for the body are sold separately
    • Geared differential delivers smooth cornering
    • Full ball bearing specifications
    • Can be fitted with an optional gyro unit MZW711 (sold separately) for even easier control. Gyro sensitivity can be adjusted using the volume on the chassis
    • Compatible with wide range of MINI-Z Racer optional parts so you can enjoy tuning and enhancing your model
    • Kyosho Mini-Z Lava Orange Porsche 911 GT3 RS MR-04 1/27 Scale RWD Car - RTR
    • Factory assembled chassis
    • Pre-painted body, complete with markings
    • 2.4GHz Syncro KT-531P 2.4GHz transmitter
    • Front tread adjustment parts set
    • Pinion gears (6T, 7T, 8T, 9T)
    • Spare nuts
    • Wheel wrench
    • Pinion gear tool
    • Tires and wheels
    AGE LEVEL :11 and up
    SKILL LEVEL :Beginner
    BUILD TIME :None
    Model Scale 1/27
    Length 168mm / 6.6in
    Width 72mm / 2.8in
    Height 48mm / 1.9in
    Weight (No Battery) 169g / 5.96oz
    Wheelbase 90mm / 3.5in
    Ground Clearance N/A
    Body ABS plastic
    Chassis MR-04N-RM
    Drivetrain RWD
    Wheel Hex Size N/A
    Tire Tread F: 59.5mm R: 59mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 6T, 7T, 8T, 9T
    Spur Gear N/A
    Differential N/A
    Ball Bearings Full
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Smooth paved surfaces
