DB20 Pika Green 1/20 Scale 4WD Desert Buggy - RTR from Primus - PRM1008-002
DB20 Pika Green 1/20 Scale Brushless 4WD Desert Buggy - RTR from Primus - PRM1009-002
DB20 Pika Orange 1/20 Scale 4WD Desert Buggy - RTR from Primus - PRM1008-001
DB20 Pika Orange 1/20 Scale Brushless 4WD Desert Buggy - RTR from Primus - PRM1009-001
This comes in both a brushed and a brushless version.
Version Info: Fully assembled and ready-to-run, this model requires the addition of 3 AA alkaline batteries for the transmitter (not included).
Mini and Micro model bashers will enjoy the new Primus DB20 Pika 1/20 scale 4WD desert buggy, now available exclusively from Motion RC! This compact, feature-packed model includes a durable metal chassis plate, metal driveshafts, reliable brushed motor with heatsink, Lithium-Ion battery pack with convenient USB charger, 2.4GHz pistol-grip transmitter, LED lights and more. High-grip tires deliver maximum traction on a wide variety of surfaces while the functional rear-mounted spare tire and wheel add realism and flair!
Elevate your bashing game without emptying your wallet by combining the versatile, durable, performance of the Primus DB20 Pika with Motion RC’s industry-leading customer service, product selection, and complete parts support for a package that cannot be beat!
| Ready for Action The conveniently sized, 1/20 scale Primus DB20 Pika arrives fully assembled and ready to run. Install 3 AA alkaline transmitter batteries and prepare for a fun driving experience! |
| LED Light System Bright LED headlamps and lightbar illuminate the road in low light conditions, with a convenient red LED located at the back for safety in rain and other adverse conditions. |
| Convenient Body Mounts The cam-style rear mounts offer security while the traditional front posts use clips with flexible rubber keepers installed for ease of use. |
| Aluminum Chassis Plate Unique in this scale and price, the metal chassis and upper deck provide strength, performance, and durability to the model. |
| Integrated Wheelie Bar The DB20 Pika comes standard with an integrated wheelie bar to ensure control during those full-throttle launches! |
| Complete Roll Cage The DB20 Pika features a durable, molded nylon roll cage for strength and rigidity, as well as offering a secure and convenient fitment for replaceable body panels. |
| Intelligent Equipment Layout The DB20 Pika includes a metal chassis top brace for improved rigidity and drivetrain alignment, while the reliable brushed motor features an included heat sink for improved efficiency. The 2.4 GHz receiver and electronic speed control are placed conveniently above the chassis center brace for easy user access. |
| Versatile Suspension Coil-over composite dampers deliver impressive handling on a wide range of conditions and surfaces, while anodized aluminum damper caps add strength and style. |
- Fully assembled and ready to run
- Anodized metal chassis plate and upper deck
- 4WD with twin differentials
- Coil-over friction dampers
- Molded chassis mud guards
- Oilite bronze bushings
- Functional spare wheel/tire included
- Reliable brushed motor with heat sink
- Durable metal center driveshaft, rear dogbones, and front CVD joints
- Integrated wheelie bar
- Factory-painted body available in two attractive colors
- LED light bar, headlights, and taillight
- Integrated ESC/RX
- Primus DB20 Pika Green 1/20 Scale 4WD Desert Buggy - RTR
- 2.4GHz transmitter
- 2S 7.4V Li-ion battery
- USB charger
- Quick start guide
- Tools and spare parts
- 3x AA alkaline batteries for the transmitter - we recommend the Admiral AA NiMH 2600mAh Rechargeable Batteries (Pack of 4)
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : None | Model Scale | 1/20 |
| Length | 245mm / 9.5in |
| Width | 153mm / 6.0in |
| Height | 114mm / 4.5in |
| Weight (No Battery) | 555g / 19.8oz |
| Wheelbase | 146mm / 5.8in |
| Ground Clearance | 21mm / 0.8in |
| Body | Polycarbonate, painted and decorated |
| Chassis | Aluminum |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 61 x 25mm |
| Wheel Hex Size | 8mm |
| Tire Tread | Multi-surface |
| Bushing Material | Oilite |
| Suspension | Independent |
| Shock Type | Coil-over friction dampers |
| Transmission | Direct drive |
| Gear Pitch | M0.5 |
| Internal Gear Ratio | 3.6:1 |
| Final Drive Ratio | 14:1 |
| Pinion | 16T |
| Spur Gear | 58T |
| Differential | Planetary gear |
| Ball Bearings | Complete |
| Brakes | Electronic |
| Electronic Speed Control | 35A with JST connector |
| Motor | 380 brushed |
| Battery | 2S 7.4V 600mAh lithium-ion (included) |
| Max Battery Dimensions (L x W x H) | 48 x 26 x 30mm |
| Servos | Waterproof |
| Radio | 2-channel (included) |
| Lights | Yes |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Beginner |
| Assembly Time | None |
| Recommended Environment | Indoors/Outdoors |
