Official Primus DB20 Pika 1/20 Scale 4WD Desert Buggy Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	69aa1660_primus-db20-pika-green-1-20-scale-4wd-desert-buggy-rtr.webp Views:	0 Size:	58.0 KB ID:	445396
    Click image for larger version  Name:	69aa1660_primus-db20-pika-orange-1-20-scale-4wd-desert-buggy-rtr.webp Views:	0 Size:	93.4 KB ID:	445397
    This comes in both a brushed and a brushless version.
    Version Info: Fully assembled and ready-to-run, this model requires the addition of 3 AA alkaline batteries for the transmitter (not included).
    Mini and Micro model bashers will enjoy the new Primus DB20 Pika 1/20 scale 4WD desert buggy, now available exclusively from Motion RC! This compact, feature-packed model includes a durable metal chassis plate, metal driveshafts, reliable brushed motor with heatsink, Lithium-Ion battery pack with convenient USB charger, 2.4GHz pistol-grip transmitter, LED lights and more. High-grip tires deliver maximum traction on a wide variety of surfaces while the functional rear-mounted spare tire and wheel add realism and flair!
    Elevate your bashing game without emptying your wallet by combining the versatile, durable, performance of the Primus DB20 Pika with Motion RC’s industry-leading customer service, product selection, and complete parts support for a package that cannot be beat!
    Ready for Action
    The conveniently sized, 1/20 scale Primus DB20 Pika arrives fully assembled and ready to run. Install 3 AA alkaline transmitter batteries and prepare for a fun driving experience!
    LED Light System
    Bright LED headlamps and lightbar illuminate the road in low light conditions, with a convenient red LED located at the back for safety in rain and other adverse conditions.
    Convenient Body Mounts
    The cam-style rear mounts offer security while the traditional front posts use clips with flexible rubber keepers installed for ease of use.
    Aluminum Chassis Plate
    Unique in this scale and price, the metal chassis and upper deck provide strength, performance, and durability to the model.
    Integrated Wheelie Bar
    The DB20 Pika comes standard with an integrated wheelie bar to ensure control during those full-throttle launches!
    Complete Roll Cage
    The DB20 Pika features a durable, molded nylon roll cage for strength and rigidity, as well as offering a secure and convenient fitment for replaceable body panels.
    Intelligent Equipment Layout
    The DB20 Pika includes a metal chassis top brace for improved rigidity and drivetrain alignment, while the reliable brushed motor features an included heat sink for improved efficiency. The 2.4 GHz receiver and electronic speed control are placed conveniently above the chassis center brace for easy user access.
    Versatile Suspension
    Coil-over composite dampers deliver impressive handling on a wide range of conditions and surfaces, while anodized aluminum damper caps add strength and style.
    Features:
    • Fully assembled and ready to run
    • Anodized metal chassis plate and upper deck
    • 4WD with twin differentials
    • Coil-over friction dampers
    • Molded chassis mud guards
    • Oilite bronze bushings
    • Functional spare wheel/tire included
    • Reliable brushed motor with heat sink
    • Durable metal center driveshaft, rear dogbones, and front CVD joints
    • Integrated wheelie bar
    • Factory-painted body available in two attractive colors
    • LED light bar, headlights, and taillight
    • Integrated ESC/RX
    Includes:
    • Primus DB20 Pika Green 1/20 Scale 4WD Desert Buggy - RTR
    • 2.4GHz transmitter
    • 2S 7.4V Li-ion battery
    • USB charger
    • Quick start guide
    • Tools and spare parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/20
    Length 245mm / 9.5in
    Width 153mm / 6.0in
    Height 114mm / 4.5in
    Weight (No Battery) 555g / 19.8oz
    Wheelbase 146mm / 5.8in
    Ground Clearance 21mm / 0.8in
    Body Polycarbonate, painted and decorated
    Chassis Aluminum
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 61 x 25mm
    Wheel Hex Size 8mm
    Tire Tread Multi-surface
    Bushing Material Oilite
    Suspension Independent
    Shock Type Coil-over friction dampers
    Transmission Direct drive
    Gear Pitch M0.5
    Internal Gear Ratio 3.6:1
    Final Drive Ratio 14:1
    Pinion 16T
    Spur Gear 58T
    Differential Planetary gear
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control 35A with JST connector
    Motor 380 brushed
    Battery 2S 7.4V 600mAh lithium-ion (included)
    Max Battery Dimensions (L x W x H) 48 x 26 x 30mm
    Servos Waterproof
    Radio 2-channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Indoors/Outdoors
