Official Primus Panther 1/8 Scale Brushless 4WD Buggy Discussion Thread
Does the ESC come preset for 4S out of the box, or do we need to program it before the first run? -
Version Info: This model arrives fully assembled and ready for use; however it requires four (4) AA alkaline transmitter batteries, a 3S or 4S LiPo battery with XT90 connectors, and a suitable charger (all available separately, not included).
Few RC driving experiences deliver the power, precision, and performance of a 1/8 scale brushless buggy. Primus, the exclusive vehicle brand of Motion RC, is delighted to introduce the Panther, a model equally at home on the track or at your favorite bash spot. Fully assembled with a factory-decorated body, this beast arrives ready for action after adding your preferred 3S or 4S LiPo pack!
The lengthy list of features on this surprisingly affordable model include a rigid 3mm aluminum chassis plate with molded dirt guards, robust 3mm aluminum shock towers, three planetary sealed fluid-filled differentials with metal bevel and crown gears, steel spur gear, oversized aluminum shocks with threaded adjusters, and lower molded spring perch protectors to keep away dirt and debris. A ZTW Beast 160A ESC provides multiple tuning options, with additional options available via Bluetooth module and ZTW app, or an LCD programming box. The sealed, sensorless 4-pole 2150kV brushless motor delivers massive torque and impressive top speeds, while the injection-molded rear wing provides the necessary aero downforce to keep the Panther planted on the track. A metal-geared 30Kg servo is responsible for the Panther’s razor-sharp steering response, and the reliable 2.4GHz radio system yields interference-free control. In addition, when you’re ready to go Pro, Primus offers a complete assortment of upgrade parts that enhance durability and handling. Click the Upgrades tab above for the complete assortment.
Combine these numerous features with Motion RC’s extensive parts and technical support for a truly exceptional impressive RC ownership experience.
Fully Assembled
The 1/8 scale Panther is delivered factory-assembled and ready for transmitter batteries and your choice of 3S or 4S LiPo battery pack.Supreme 4WD Performance
The Panther features a traditional layout preferred by leading designers, favored for its durability, handling, and ease of tuning and maintenance. The center diff features a protective composite dust cover to keep the spur and pinion gears free from dirt and debris.Proven C-Hub Front Suspension
Chosen for reliability and durability with minimal sacrifice to the adjustability of pivot-ball style front suspensions, the Panthers front suspension was proven over months of testing. Precision aluminum drive hexes and wheel nuts deliver reliability and precision while headed and threaded lower hinge pins to eliminate the inconvenience of tiny e-clips and deliver the ultimate in security and the confidence to go full send.Adjustable Composite Rear Hubs
The composite rear hubs offer three different upper arm length settings for a wide range of camber gain and roll center adjustments, while the wheelbase is fully adjustable via lower hinge pin spacers. Aluminum drive hexes and wheel nuts provide precision and are often an expensive option on other models in this price class.Oversized Aluminum Shocks
The premium handling of the Panther is primarily due to its oversized threaded aluminum shocks. Utilizing an aluminum body, upper and lower caps, and threaded adjuster nuts, the dampers perfectly combine the durability demanded by bashers and the precision required by racers. The composite lower spring perch dirt guards keep the spring aligned and the lower perch free from stones and roost when trailing other vehicles.Outstanding Electronics
The ZTW-made 160A ESC has forward and reverse, with an included selectable forward-only program for competitive racing. The cooling fan and on/off switch feature a protective guard to eliminate threats from dirt and debris.Power to the Panther
The sealed, 4-pole sensorless brushless motor delivers impressive power on a wide range of track or bash surfaces, while the adjustable metal motor mount allows for easy gear mesh adjustments.Features:Numerous Pro-Level Features
The sealed radio box protects and insulates the receiver, while the aluminum servo arm with an adjustable turnbuckle steering bellcrank link offers convenience and improved reliability. A ball bearing-equipped servo saver provides adjustable tension, helpful when transitioning from bashing to racing. Features like these are almost never found in affordable models like the Primus Panther.- Fully assembled, ready for your choice of 3S or 4S LiPo battery
- 160A forward/reverse programmable ESC
- Powerful 4-pole 2150kV sensorless brushless motor
- Reliable 2.4GHz pistol grip radio
- Metal geared 30kg steering servo with aluminum servo arm
- Durable composite lower suspension arms and hubs
- Adjustable turnbuckle upper camber links and steering tie rods
- Aluminum drive hexes and wheel nuts
- 4WD system delivers incredible acceleration and handling
- Durable aluminum chassis plate and shock towers
- Three sealed, fluid-filled differentials with metal crown and bevel gears
- Oversized aluminum oil-filled shocks with threaded spring adjusters
- Front and rear adjustable anti-roll bars
- Ball bearing-equipped drivetrain, outdrives, and servo saver
- Durable C-hub front suspension with headed hinge pins
- Robust aluminum steering slider with adjustable Ackerman
- Aerodynamic injection-molded rear wing
- Factory-decorated and trimmed polycarbonate body shell
- Mounted and glued mini-pin tires with foam inserts
- Quick start guide
- Supplemental stickers
- Hex wrenches and nut driver
- Primus Panther 1/8 Scale Brushless 4WD Buggy - RTR
- 2.4GHz pistol grip transmitter
- Maintenance tools
- Quick start guide
- Radio/ESC manual
- Exploded view parts reference
- Stickers
- 3S-4S LiPo hardcase battery with XT90 connector - we recommend the Admiral 5300mAh 4S 14.8V 60C Hard Case LiPo Battery with XT90 Connector
- 4 x AA alkaline batteries for the transmitter - we recommend the GP Super Alkaline 1.5V AA Batteries (4 pack)
- 4S compatible battery charger - select a suitable charger from our Charger Collection
AGE LEVEL : 14 and Up
SKILL LEVEL : Beginner
BUILD TIME : Less Than 10 Minutes Model Scale 1/8 Length 520mm / 20.4in Width 300mm / 11.8in Height 195mm / 7.6in Weight (No Battery) 3220g / 113.5oz Wheelbase 330-337mm / 13-13.2in Ground Clearance 45mm / 1.7in Body Polycarbonate, factory painted and decorated Chassis 3mm 6061 aluminum Drivetrain 4WD Wheel Size (Diameter x Width) 115 x 44mm Wheel Hex Size 17mm Tire Tread Multi-surface Bushing Material N/A Suspension 4-wheel independent Shock Type Oil-filled, coil over, adjustable Transmission Direct drive with 3 differentials Gear Pitch 1.0 Internal Gear Ratio N/A Final Drive Ratio 10.14 Pinion 15T metal Spur Gear 46T metal Differential Three oil-filled/metal bevel gear Ball Bearings Complete Brakes Electronic Electronic Speed Control 150A with XT90 connector Motor 2150kV 4074 brushless inrunner Battery 3S-4S LiPo with XT90 connector (required) Max Battery Dimensions (L x W x H) 140mm x 50mm x 46mm (4S) / 140mm x 50mm x 38mm (3S) Servos 30kg waterproof, metal gear Radio 4-channel (included) Lights No Sound No Water Resistant Yes Skill Level Beginner Assembly Time Less than 10 minutes Recommended Environment Outdoors
