The 300 series mark the modern era of Cat® excavators, with over 60 models available today. No machine stands more proudly than the Caterpillar® 330D L , the “L” referring to a long undercarriage design for improved traction and stability. With an operating weight of more than 35 tons, the 330D L raised the bar for the category. Now, Motion RC proudly offers the DCM Cat® 330D L replica in 1:20 scale radio control diecast metal model. Officially licensed by Caterpillar®, this model perfectly replicates the color, graphics, and operation of the 1:1 scale vehicle. When operating the model, you will instantly feel the power and precision that have made Cat® the world’s largest and most respected name in earthmoving!
Combine this incredible diecast operating replica with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
Impressive Presence At almost 19” long and weighing over 12 lbs., the Diecast Masters 330D L creates an impressive presence at your scale construction site. Officially licensed Caterpillar® paint and graphics result in an impressive model at work or on display. |
A Complete Package In addition to its RTR format, the 330D L includes protective packaging to protect your model during storage or transportation to the worksite. |
- Genuine Caterpillar® Yellow paint, a color available only to licensees of Caterpillar Inc
- Copyrighted "Power Edge" trade dress reflects look of 330D L machine built between 2006-2008
- Individual boom, stick and bucket movements mimic the real 330D L
- Precision track control for forward, reverse, and steering actions
- Realistic 360-degree rotation accommodates dig, carry, and dump operations
- Sound system mimics engine noise as well as track, swing arm, boom, stick, and bucket movements
- Robust mechanics for strength and durability
- Precision-machined gear set
- Precision roll-screw style, ball-bearing supported transmission and drive system
- Heavy-duty diecast components
- Efficient motors and extended use rechargeable battery provides 45-60 minutes of operation on a single charge
- 1/20 Scale Caterpillar 330D L Diecast Excavator - RTR
- 2.4 GHz Transmitter
- 7.4V 2000mAh Rechargeable LiPo Battery Pack
- USB Charger
- AAA batteries for Transmitter
- Nothing, everything is included
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : Less Than 15 Minutes
Scale | 1/20 |
Length | 521mm / 20.5" |
Width | 178mm / 7" |
Height | 479mm / 18.8" |
Weight | 5,700g / 200oz |
Wheelbase | N/A |
Ground Clearance | N/A |
Body | Metal, factory painted and decorated |
Chassis | Metal |
Drivetrain | 2WD |
Wheel Size (Diameter x Width) | N/A |
Wheel Hex Size | N/A |
Tire Tread | N/A |
Bushing Material | N/A |
Suspension | N/A |
Shock Type | N/A |
Transmission | Metal-geared |
Gear Pitch | N/A |
Internal Gear Ratio | N/A |
Final Drive Ratio | N/A |
Pinion | N/A |
Spur Gear | N/A |
Differential | N/A |
Ball Bearings | Yes |
Brakes | Electronic |
Electronic Speed Control | Forward/Reverse with XT30 connector |
Motor | Dual brushed |
Battery | 2S LiPo with XT30 connector (included) |
Max Battery Dimensions (L x W x H) | N/A |
Servos | N/A |
Radio | Multi-Channel (included) |
Lights | No |
Sound | Yes |
Water Resistant | No |
Skill Level | Beginner |
Assembly Time | Less Than 15 Minutes |
Recommended Environment | Outdoors |
