  • Panzermechaniker
    That's incredible. I started building at the same time and the tanks got me through all the Covid lockdowns. My funds and space available hit their limit though😀
  • DavidN
    Originally posted by Panzermechaniker View Post
    Your tank collection boggles the mind.👍 How long did it take you to amass it? I don't feel so bad now with my total of 13😉😀
    I have been into tanks for a long time but mostly static models. If you asked about amassing, I started buying them when we were into the second year of Covid. I was so bored and started buying, painting and weathering them at the rate of one tank a week; sometimes 2 tanks a week. My first IR battle was with the LA Tank Club in August 2021.
    My Russian fleet....
ID:	373385Click image for larger version
    My Panthers....
ID:	373387Click image for larger version
  • Panzermechaniker
    Originally posted by DavidN View Post
ID:	373298Click image for larger version
ID:	373299Click image for larger version
  • Skid Kid
    My babies!!!!!
  • DavidN
    Originally posted by MrChef View Post
    Very cool David! I really dig the Jagdtiger in Grey. Is 204 full metal unpainted a Mato or other?
    The 204 at the far left is a Tamiya. The 204 in the middle is the unpainted full metal Mato. I kept it unpainted so it will join the other 2 Panzers to be in the next Battlestar Galactica, lol.
  • MrChef
  • DavidN
  • DavidN
ID:	373294Click image for larger version
ID:	373295Click image for larger version
  • DavidN
    My Royal family of King Tigers.
ID:	373291Click image for larger version
  • DavidN
    Nice collection David!
    Are both 122 and 321 Tamiya? If so I see slight differences between them. Are they just different options you chose to go with IE the different exhaust and location of jack block?
    And how did you do the kill tally rings on the barrels? Freehand or decals? TIA.
    Keep it up.
    Chef
    Yes! They are both from Tamiya. And yes, the Tamiya kit had 2 different exhausts types (options) for the modeller to choose.
    The kill ring marks are decals from Forgebear:
    Forgebear Tanks are Taigens UK authorised distributor and supplier. All Taigen parts listed are genuine. We also stock 1:16 scale tanks and parts from various manufacturers, such as Atak, Heng Long, Voyager, Hooben, Aber, SOL, DKLM, Mato and Tamiya.
  • MrChef
ID:	372735Click image for larger version
ID:	372736Click image for larger version
    Keep it up.
    Chef
  • DavidN
  • DavidN
ID:	372731Click image for larger version
ID:	372732Click image for larger version
  • DavidN
    My jagdpanthers...
ID:	372728Click image for larger version
  • 761st
    Nice piece. Mine comes off the TC right rear, I do have a repair that I need to install. It will have to wait.
  • cmdrcody
    Originally posted by 761st View Post
    interesting. Where did you come by this?
    Well, my Tiger1 seemed to like to slip the metal track slightly to the outside occasionally. The Tiger1 Pro version already has a driveshaft bearing in the chassis, so I knew this wasn't a reason for this issue. What I did see was a large gap between the outer drive sprocket and guide teeth with no anti-slip ring on the drive sprocket. So after looking for a anti-slip ring or a drive sprocket that indeed have one built into it with absolutely no results, I decided to fabricate and install my own anti-slip ring epoxied to the inside of the outer drive sprocket which about 95% cured this issue of the track slipping to the outside. And if it did, by making a quick turn to the side of which it did slip, the metal track moved back onto the teeth of the drive sprocket. Maybe I need to patent this?
    Click image for larger version  Name:	20230228_161145.jpg Views:	0 Size:	134.8 KB ID:	372532Click image for larger version  Name:	20230228_160419.jpg Views:	0 Size:	127.0 KB ID:	372533
  • quitcherbitchen
    like that- explain please?
  • 761st
  • cmdrcody
    Here's my fix for that.
ID:	372501Click image for larger version
  • 761st
    In spite of all that interferers with the joys of life, we managed a little tank time and threw a track in the process.
