  • SoCalBobS
    A T-35, a KV-1 and an officer!
  • SoCalBobS
    KV-1E in worn winter camo. My first foray into 'heavy chipping fluid".
  • SoCalBobS
    T-35 Road Testing:
  • Sappo
    Was a bit hot the other day so I took the kv1 for a bit of a paddle in the water Click image for larger version
  • RichJohnson
    My Marksman Sherman performed well for its first battle. Click image for larger version
ID:	336956Click image for larger version
  • quitcherbitchen
    I found this stuff for weathering from a guy on the RCTANKWARFARE website. He is a Californian. Magic Grime fromClick image for larger version
Name:	Magic Grime.jpg
ID:	336927 Jnewboy $21 shipped. Comes in three different flavors.
  • Rubicon99
    Originally posted by Hellcat 7 View Post
    Very nice Paint! Do you pre-shade all your tanks with black or dark gray?
    I can not speak for the two tanks on either side of the Centurion those belong to DavidN here on HS. DavidN does some really nice paint work.
    I do not pre-shade my “battling” tanks with paint. I do dust on chalks and then rub it into the high points and panel joints. I typically only use three maybe four colors of chalks mostly bright rust, dark rust and black. Then some oil to simulate fuel spills or joint grease spread. After that I let natural weathering dirt, dust and mud do the rest. Usual it takes about a month of use for enough natural weathering builds up before I call a tank done. In the above Centurion photos it has almost no natural weathering and to me eye still has a long way to go to achieve the grimy field use I like on my “battling” tanks.
    Now my display tanks are a totally different story. I use completely different methods to achieve a given look on them. Mostly done though paint with chalk hi lights.
  • Hellcat 7
    Pre battle day photos. Tamiya Centurion parked between a Tiger and JagPanther.
ID:	336874 Tamiya 1/16 Centurion tank.
  • Rubicon99
  • Rubicon99
    Tamiya Centurion 1/16 RC tank in mid-late 1960s IDF theme. Click image for larger version  Name:	75D6ACC7-2EFA-4531-AF29-35912880ADC4.jpeg Views:	15 Size:	126.2 KB ID:	336039Click image for larger version  Name:	76B186CA-DDAE-4687-A809-45374B89A9F5.jpeg Views:	16 Size:	363.1 KB ID:	336040Click image for larger version  Name:	ECC61DC8-207B-463A-A1AD-474213E2545F.jpeg Views:	22 Size:	142.6 KB ID:	336038
  • Vaseline
    So when im doing a wash with tanks that have the dunkelgelb for german armor, or tan tanks in general, I used a wash made by citadel called "Seraphim Sepia" you can reverse engineer it if you like but I find anything else too dark for a tan tank, although I do use a brown and black wash in strategic locations like where there would be grease or water would carry engine soot and such. Again I use Citadel products for those; Flat Nuln Oil which is black.(they make a gloss Nuln oil, and that works for spilled petrol) and Agrax Earth, which is a medium brown. They might not be everyones cup of tea as they are an acrylic wash and dont flow as nicely as an enamel based wash. that being said, I personally like them and what I use.
  • DavidN
    I like very much the true opinions and advice from everyone. That's one of the reason we post our results. Thank you :-)
  • Vaseline
    It just looks really wierd first being so dark, and then the zimmerit is all weathered, and the flats look factory pristine, If it where me Id give it a bit of diffusing with the tan basecoat to tone down the stripes, and decal. But hey, your tank man,I aint gunna tell you how to do your tank.
  • DavidN
    Originally posted by Vaseline View Post
    I personally would have gone with a sepia or brown wash, the black is a bit too much contrast with the tan IMO, other than that good painting.
    You are right. I did add about 1/3 of the brown in my mixture but the indoor light deceived my observation. I will fix it this weekend.
  • Vaseline
  • DavidN
    Yeap! I repainted it and added more stripes. I gave it a black wash on those zimmerit area and the wheels. I drybrushed the edges too.
  • DavidN
ID:	333953Click image for larger version
  • Rubicon99
    Originally posted by DavidN View Post
ID:	333949Click image for larger version
    You repainted Jeff’s Elephant? Looks very different but good.
  • DavidN
  • DavidN
    My last project of the year...is done.
