Magnitizing your tank
  • Sappo
    • Feb 2020
    • 346
    I figured that while I had the m1a2 in bits for a clean up after her muddy day out I would do a few mods to her. First being magnets to secure the top deck. Easy job to do, just did it in stages. Click image for larger version
ID:	245314Click image for larger version
  • Sappo
    • Feb 2020
    • 346
    You can also see the other mod was cutting the battery box so I don't have to flip her on the side to change out the battery anymore, also moved the power switch inside and will be sealing that and the battery box as well. Then it's on to some steel to make the body a bit more rigid. So watch this space.
    • Rubicon99
      • 3316
      When using magnets to hold the body on it is a good idea to also use metal hull stiffening braces since the unibody effect of the screw down points is lost. Good to see you are going to do this mod too. Looking forward to your posts and photos to follow.
      • Sappo
        • Feb 2020
        • 346
        Thanks mate, will definitely post pics. Got 2 questions for you, do you think 1mm would be thick enough for bracing, its all i got to use. And do you know of any other Kiwis in the group
        • Rubicon99
          • 3316
          1mm of steel should be fine depending on your bracing layout and given what I see of your Abrams in the photos. You are only running 380 motors and plastic tracks so you will not see much flexing. Flexing of the hull really starts to be see with heavy metal tracks and metal suspension components.
          Sorry I do not know of any other Kiwis on this forum. But we all welcome you with open arms.
          • Sappo
            • Feb 2020
            • 346
            Hey thanks for that mate. That's one problem here, rc tankers seem to be few and far between. Does make for a bit of a lonely hobby.
            • Sappo
              • Feb 2020
              • 346
ID:	245383Click image for larger version
ID:	245388 dry fitting first Click image for larger version
ID:	245389Click image for larger version
ID:	245384Click image for larger version
ID:	245385 ell that's the bracing done, was a pretty easy job, just one step at a time
              • Sappo
                • Feb 2020
                • 346
                Look mum, no flex
                • Beeg
                  • 1335
                  • Texas
                  Look mum, no flex
                  What glue did you use? Epoxy?
                  • Sappo
                    • Feb 2020
                    • 346
                    Yep. A unbranded epoxy I have been using for years now from the $2 shop here in NZ. Also good for casting as well. Now all I have to do is get hold of some red motor's and metal running gear and I think that'll be that. Oh and does the 5.3 system work with IR?Cause I have a plan to build a bit of a biathlon track in the backyard as well. Could make it for airsoft but I think IR would be a better option.
