Glazing the m1a2
  • Sappo
    • Feb 2020
    • 346
    Glazing the m1a2
    How do you remove the commanders cupola from the m1a2. Got everything else done just got the tc vision blocks to do
  • Rubicon99
    • 3316
    It is CA glued on. Some are easy to remove so a real B****!!
    • Sappo
      • Feb 2020
      • 346
      They glued all the way round including the tub or just the 4 pins. Cause I would like to remove the dog house and do that as well
      • Rubicon99
        • 3316
        Sometimes both, sometimes just the pins. Believe me I have wanted to pull my hair out over the hit and miss of HL glueing practices.
        Just take it slow when prying cupola off. If you damage it beyond repair don’t worry HL sells replacements.
        • Sappo
          • Feb 2020
          • 346
          Well I piked out on removing the cupola and just inserted the glazing in from the outside. Didn't add any color to them,I don't paint the ones in my 1/35 scale tanks either because I don't think they look right. Here is the end result. Click image for larger version
ID:	247851Click image for larger version
ID:	247852Click image for larger version
