Tamiya 1/16 Scale US M26 Pershing Medium Tank
This is the 1/16 electric radio-control assembly kit of the U.S. Medium Tank M26 Pershing that made its appearance during the end of WWII.
Overall length: 536mm, overall width: 218mm, overall height: 197mm. Despite its large scale, the model has been thoroughly and accurately reproduced.
Not only can the model move forward and backward and turn with a great sense of power, but the turret can be rotated and the gun raised and lowered. Recoil of the gun and movement of the hull during shooting are also perfectly reproduced and synchronized.
The sound of the engine has been recorded from a real Ford GAF Liquid cooled V8 engine, the metallic clanking sound of the tracks and the sound of the shooting of the main gun adapt to the model"s movement. Moreover, this kit features headlights and brake lamps that light-up and main gun and front machine gun that flash.
The sound of the engine was digitally recorded from a real Ford GAF liquid cooled V8 engine of the M26 Pershing at the Ropkey Armor Museum. All the variation of sound of the real engine but also all the metallic clanking of the track has been thoroughly recorded.
Note: The instructions for "Preparing for Operation" on page 2 of the Operations Manual has been replaced with these instructions. Please refer to these instructions for recharging battery.
"Charging battery is required before operation. Charge battery after detaching from the model. Remove screws from right and left driver"s hatches, then lift the front upper hull 1cm to take the battery out. When detaching battery, be careful not to misplace cables to avoid hindering turret rotation or other movement. When charging, follow the instructions supplied with battery and charger."
Visit the Official Product Page Here
Realistic Firing Action Main gun firing action is one of the most impressive features of this model. When firing, muzzle flashes, speaker roars and recoil gearbox retracts gun barrel, then slowly returns it to standard position. |
| 340 Degree Turret Rotation The turret can be rotated approximately 340 degrees. The gun barrel can be controlled within a 20 degree range. The moving speed can be controlled by transmitter stick. |
Independent Suspension Independent suspension is damped by torsion bar springs, just like the full size M26. Combined with pre-assembled track, they provide smooth, exciting and realistic maneuverability, even on rough terrain. |
| Exceptional Realism The tank commander figure is recreated with realistic detail. This model also recreates distinctive features of the M26 such as cylindrical commander's cupola, smoke dischargers, turret w/pistol port, air cleaner, equipment and texture of armor plates. |
Easy Access Access to the control unit is simple and easy. |
| High Torque System Equipped with a factory-assembled independent twin gearbox and powered by two RS-380 motors and has a 36.98:1 gear ratio. The high torque system enables the heavy 4,100g tank to maneuver superbly. |
- Front-mounted gearbox contains two Type 380 motors that can operate together or individually to produce forward/reverse running and pivot turning
- Metal torsion bars and suspension arms combine with the wide tracks to smoothly absorb bumps and dips in the terrain and provide high maneuverability
- Realistic engine sounds accompany the tank as it starts up, drives, and stops to idle
- Hull-mounted main gun can be elevated, depressed, and swung to the left and right
