Are Torro tanks worth buying?
  • dai phan
    • Sep 2020
    • 726
    I see Torro tanks are metal and more than double the price of HL. Worth it? Thanks Dai
  • Rubicon99
    • 3311
    Yes and No. All depends on what you are looking for and how you plan on using the tank.
    Many of their parts are stock HL or are direct fit with HL tanks.
    Tagien WW2 tanks usually have a much nicer paint jobs then HL WW2 tanks.
    • dai phan
      • Sep 2020
      • 726
      I look at Taigen tanks on Amazon but all have BB rather than IR. I want to do IR battles so BB does nothing for me. Dai
      • Rubicon99
        • 3311
        You have to convert them to IR. Which means a new MFU and IR receivers and emitter.
        • dai phan
          • Sep 2020
          • 726
          Isn't IR the standard these days? Conversion means at least 150 more bucks on a 450 dollar tank! Dai
          • Rubicon99
            • 3311
            It is for HL and Tamiya but not Taigen. The Taigen MFU is not compatible with either HL or Tamiya battle systems and in stock form can’t fight with them.
            So yes you will have to add at least $100 to the price to make a stock Taigen IR compatible.
            • BcuriousR
              • 133
              • Colorado
              I like Taigen tanks. They're heavy, well built, but the electronics lack a bit. I buy their kits, then build it the way I want. Why would you order one on amazon or anywhere other than directly from Taigen, https://www.taigentanks.com ?
              BTW: A Mako board, (less than 30.00 http://rctanksaustralia.com/store/in...&products_id=2), will convert the Taigen and older Heng Long to Tamiya compatibility, but will still not match the flexibility, sound, etc. from a board like IBU2U, (my favorite).
              • dai phan
                • Sep 2020
                • 726
                Originally posted by BcuriousR
                I like Taigen tanks. They're heavy, well built, but the electronics lack a bit. I buy their kits, then build it the way I want. Why would you order one on amazon or anywhere other than directly from Taigen?
                The reason being no hassle return. I really like the metal so I would like to try one and see. Too bad they are not IR compatible with HL. Dai
                • BcuriousR
                  • 133
                  • Colorado
                  Erik at Taigen is a good guy, tanker, and goes out of his way to support the hobby. You would be better served to go to the source. Just my opinion. I've bought, built, and sold a few tanks over the years and in this niche hobby, good resources like Erik at Taigen, Ian at RCTankElectronics, and Kevin at RCTanksAustralia, are hard to find.
                  Can you specifically name anyone at amazon or even Heng Long that will personally handle your tank/purchase or follow you through troubleshooting?
                  • dai phan
                    • Sep 2020
                    • 726
                    I look at the Taigen site and I can choose the option of IR as a RTR package. I have 3 HL tanks ( Leopard, Challenger, T-90) and look for one more. What do you suggest as a Taigen tank? Dai
                    • dai phan
                      • Sep 2020
                      • 726
                      What do you think? Since I have 3 HLs already, maybe a metal one will be a good choice?
                      https://www.taigentanks.com/collecti...-metal-edition
                      https://www.taigentanks.com/collecti...35669561901223
                      • Rubicon99
                        • 3311
                        Stock Taigen IR systems are NOT compatible with HL or Tamiya. The Mako add on conversation system is unreliable with very limited range. At our battle days because of the spotty performance of the Mako to Taigen conversation and lack of range, they are limited to were and when then can engage other tanks. IMO not worth the time and money.
                        The Taigen tanks are high quality, but to reliability battle them with other makes you really need to swap out to a Tamiya compatible MFU like the HL 6.0/1, Clark T? , IBU2 or event the super expensive Tamiya MFUs.
                        • dai phan
                          • Sep 2020
                          • 726
                          I look at the Torro tanks. They look very similar to HL. Aren't they metalized versions? Dai
