Official Heng Long 1/16 Scale Soviet Union T-34 Medium Tank - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    1/16 Scale Soviet Union T-34 Medium Tank Upgrade Edition by Heng Long - RTR - HLG3909-001
    1/16 Scale Soviet Union T-34 Medium Tank Professional Edition by Heng Long - RTR - HLG3909-002
    With its surprise introduction in 1940 and later fighting in the famed Battle of Kursk, the Soviet built T-34's sloped armor revolutionized tank design and forced the Axis to scramble for a response to this new Allied weapon. This Upgrade version features steel gears and plastic tracks for an economical balance between durability and weight. Heng Long has produced RC tanks for over 20 years, and their products offer an ideal starting point for new customers wanting to explore the world of RC tanks. All of Motion RC’s Heng Long 1/16 scale tanks utilize the latest TK6 MFCB for outstanding control, performance, playability, and upgrade potential!
    Durable Tracks
    Confidently conquer terrain with durable tracks that are easy to service. Professional Versions feature metal tracks.
    Independent Suspension and Steel Geared Gearbox
    Reliable steel geared gearboxes transfer power while independent suspension provide traction over rough surfaces.
    Omnidirectional Proportional Control
    The latest generation TK6 Multi-Function Control Board (MFCB ) provides smooth driving response and personalized configuration options.
    IR Battle Ready
    Engage in friendly infrared ("IR") combat with other TK6-equipped tanks, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight!
    Airsoft BB Launch
    Safely fire 6mm plastic airsoft BBs at the included paper target at short ranges. *Take safety precautions and wear eye protection.
    Scale Detail
    The perfect balance of scale detail and practical RC Tanking, each Heng Long tank arrives factory painted and includes Cosmetic Accessory Parts to further enhance the tank's realism.
    Realistic Operation
    320 degree turret traverse, 30 degree cannon elevation, programmable track recoil, and four different sound sets put you in complete control.
    LED Lights
    LED lights indicate the tank's standby and active modes, and also flash when "hit" during IR Battles.
    Exhaust Effect
    Glycerin-based "exhaust effect" simulates engine exhaust for added realism.
    RTR
    The convenience of "Ready to Run" (RTR) allows new players to join the world of RC Tanks with ease!
    FEATURES:
    • Latest Generation TK6 Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed and low-speed modes, etc
    • Smoke effect (On/Off)
    • Headlights and Brake lights (On/Off)
    • Volume (five settings including Off)
    • Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
    • Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Fires a 6mm plastic BB (10 meters with minimal accuracy and limited velocity, but should still be treated with caution and with adequate eye protection)
    • Fires an invisible IR signal to be used as part of Heng Long's Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    • Independent suspension on all road wheels
    INCLUDES:
    • Heng Long Soviet Union T-34 Upgrade Edition 1/16 Scale Medium Tank - RTR
    • 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
    • 2S USB LiPo/Li-ion battery charger
    • 12-Channel 2.4GHz radio transmitter
    • Magnetic Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • 6mm plastic BBs (50 Pack)
    • 2x spare track links
    • Smoke oil
    • Complete instruction manual
    REQUIRES:
    • 6x AA batteries for 2.4GHz radio transmitter
    OPTIONAL:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : BEGINNER
    BUILD TIME : 1 HOUR
    Note: Professional edition has the drive sprocket, idler wheel, and tracks upgraded to cast metal.
    Scale 1:16
    Length 49cm / 19.2in/p>
    Width 19cm / 7.4in
    Height 19cm / 7.4in
    Weight 2267g / 79.9oz
    Body Material ABS Plastic
    Chassis Material ABS Plastic
    Track Material Plastic
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Idler Arm
    Sprocket Plastic
    Road Wheels Plastic
    Idler Wheel Plastic
    Adjustable Idler No
    Turret Rotation 320 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch Yes, 6mm
    Track Recoil Yes
    Cannon Barrel Recoil No
    Required Battery 2S 7.4V 1800mAh (included)
    Required Radio 10 Channel (included)
    Skill Level Beginner
    Build Time 1 Hour
