Official Tamiya 1/16 Scale German Panther Type G Heavy Tank - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    1/16 Scale German Panther Type G Heavy Tank Full Option from Tamiya - KIT - TAM56022
    Version Info: This tank is in "KIT" form and requires your own 4 Channel radio, receiver, ESC, charger and battery to run. (See Requires below for information).
    Tamiya's peerless 1/16 R/C Tank products are the ultimate in realistic indulgence, and with the German Tiger I and King Tiger already released, it is only natural that they add the famous Panther Type G to the lineup. Tamiya staff even visited the renowned collection of the Musee des Blindes in Saumur, France in order to create the most accurate Panther sounds possible. Pit it against the previously released US Sherman and Pershing tanks on your own mock battlefield.
    The front-mounted gearbox contains two Type 380 motors that can operate together or individually to produce forward/reverse running and pivot turning. Metal torsion bars and suspension arms combine with the wide tracks to smoothly absorb bumps and dips in the terrain and provide high maneuverability. In addition, realistic engine sounds accompany the tank as it starts up, drives, and stops to idle. Hull-mounted main gun can be elevated, depressed, and swung to the left and right.
    Realistic Firing Action
    Main gun firing action is one of the most impressive features of this model. When firing, muzzle flashes, speaker roars and recoil gearbox retracts gun barrel, then slowly returns it to standard position.
    340 Degree Turret Rotation
    The turret can be rotated approximately 340 degrees. The gun barrel can be controlled within a 20 degree range. The moving speed can be controlled by transmitter stick.
    Independent Suspension
    Independent suspension is damped by torsion bar springs, just like the full size King Tiger. Combined with pre-assembled track, they provide smooth, exciting and realistic maneuverability, even on rough terrain.
    Exceptional Realism
    Full of realistic detail and scale realism from top to bottom.
    Easy Access
    Access to the control unit is simple and easy.
    High Torque System
    Equipped with a factory-assembled independent twin gearbox and powered by two RS-380 motors and has a 36.98:1 gear ratio. The high torque system enables the heavy 4,100g tank to maneuver superbly.
    FEATURES:
    • Front-mounted gearbox contains two Type 380 motors that can operate together or individually to produce forward/reverse running and pivot turning
    • Metal torsion bars and suspension arms combine with the wide tracks to smoothly absorb bumps and dips in the terrain and provide high maneuverability
    • Realistic engine sounds accompany the tank as it starts up, drives, and stops to idle
    • Various workable lights such as headlights, tail lamps, brake lights, black-out lights and rotating light
    • Hull-mounted main gun can be elevated, depressed, and swung to the left and right
    INCLUDES:
    • Tamiya German Panther Type G Full Option 1/16 Scale Heavy Tank - KIT
    • Complete instruction manual
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : BEGINNER
    BUILD TIME : 1 HOUR
    Scale 1:16
    Length 52.5cm / 20.6in
    Width 23cm / 9.0in
    Height 18cm / 7.0in
    Weight 4535g / 159.9oz
    Body Material ABS Plastic
    Chassis Material ABS Plastic
    Track Material Metal
    Bearings Metal Bushings
    Gearbox Gear Material Metal
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Idler Arm
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler No
    Turret Rotation 320 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch Yes, 6mm
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V - 3S 11.1V LiPo Battery (required)
    Required Radio 4+ Channel (required)
    Skill Level Beginner
    Build Time 1 Hour
  • DavidN
    • May 2021
    • 3209
    • Los Angeles, CA
    I just want to post these pictures up for our members to see the differences of the panthers from HL, Tamiya, and Taigen.
    It seems that the Taigen is kinda small and the HL has the least details. They all run good for their perspective paying prices :-)
    • DavidN
      • May 2021
      • 3209
      • Los Angeles, CA
ID:	340060Click image for larger version
