Heng Long Panther G Spring upgrade
  • Heng Long Panther G Spring upgrade
    I have a Heng Long Panther G and the stock springs are bogged down to the point where it touches the body on the tank. I have tried making spring, which was a complete failure and I have tried clocking them further but it doesn’t work.So I am looking for some upgrade springs for my tank. I live in the US, and am trying not to spend a millions dollars on shipping.
    I had that problem with the chally 2, took the suspension apart and drilled some more holes on the first and last positions, worked perfectly
      I already tried that and it did nothing. :(
        Sounds like the issue might be overly tight tracks. This could be the cause of the issues you are describing as it is common with tight tracks. Can you post photos of your tank from the sides that clearly showing the entire track?
          I’ll put the arms, wheels, and tracks on and send a pic
              The suspension is so weak to can hold the weight of the tank
