My Heng Long tank power system had been 3 pieces of Maxamps.com 7.2 volts NiMH pack and a Duratrax Piranha Digital Peak Battery Charger. The Piranha allowed pretty quick charging of the packs and gave actual capacity reading. When all 3 Maxamps packs died and a replacement pack costs $68 each, I know that I have to do something. (Yes, I am aware of many $15, 3000 mAh packs on Amazon which may be very good.) I was never happy with the discharge curve of the NiMH where the voltage drops too fast. I want to try something different.
I found a $17 recipe resulted in a 7.4V, 5000 mAh pack with a flat discharge curve. The ingredients are:
1. 2 EBL brand 26650 Lithium Ion cells.
2. 1 dual cell 26650 SMD battery holder.
3. 1 large Tamiya connector from the dead NiMH battery pack. Or a pair of XT60 connector cables.
I sawed off the 4 plastic tabs on the side of the battery holder to make it fit the Heng Long battery bay. The soldering is simple. I am switching over to XT60 connectors, but the Tamiya work just fine too. It is more expensive and more difficult to find. The pack below was made earlier.
The EBL 26650 cells are very cost effective for this application. It is cheap at $5.50 a cell when buying 4 or more on e-bay. It holds the full 5000 mAh it specified. The current capacity is a mere 4A continuous and 8A peak, but is perfectly adequate for the slow moving Heng Long with a pair of smallish 380/390 motors. I tested the premier brand Keepower cells with 15A/30A and protection circuit which is $15 or more per cell. It makes no difference to how the tank operates. And the taller Keepower cells are more difficult to fit into the holder.
The Lithium battery needs a different type (constant voltage) of charger than NiCD/NiMH which stops charging when individual cell reaches 4.2 volts. I use the Nitecore Intellicell or the SkyRC iMAX B6 mini charger. Overcharging Lithium Ion or Li-Po cell will shorten their life or even damage the cell.
