Heng Long
  • Cameron Schaeffer
    • Oct 2021
    • 53
    Heng Long
    Does the King Tiger 7.0 have an adjustable idler wheel? Or you just have to take off one of the track links?
    • 5392
    From the Motion page...
    "The King Tiger lacks an adjustable idler like the newer Challenger II or T-72, which means fine adjustments cannot be made to track tension.".
    • Cameron Schaeffer
      • Oct 2021
      • 53
      Actually I took it apart and it does have the adjustment. The tracks work smoothly now.
        • 5392
        That’s good to know. Is it a screw adjustment or where you loosen the axle and rotate it a notch?
        • Cameron Schaeffer
          • Oct 2021
          • 53
          Yes you loosen a nut on the inside. Remove the screw on the inside of the wheel. Wiggle it a little to allow play, then make your adjustments. Naturally you have to have the tracks and wheel to do so. If I do it again I'll take some pictures to maybe better explain.
          • Cameron Schaeffer
            • Oct 2021
            • 53
            Wheel off*
