Ever since it was new my HL t34 has had a issue with the left track not feeding onto the sprocket cleanly, it would ride up on the outer edge of the sprocket before engaging properly. It was never really a problem, just annoying at slow speed. Today I looked closer and discovered the gearbox was loose. It turns out that the mounting screws have been over tensioned when assembled. What is a good fix for this problem
Gearbox mounts
So the over tensioning stripped the plastic and now the screw threads cant get a grip and are loose? If that is the case, drill out the stripped holes, glue an appropriate size piece of sprue into the hole. After the glue is set drill a small pilot hole and then put it all back together. Being careful not to over tension as the factory did.
