Barrel Smoke Flash sync
  • jenseneus
    • Mar 2022
    I just installed a barrel smoke flash on a 7.0 Heng Long tiger 1.
    I noticed that the recoil, flash and smoke are not all synchronized. probably because the old BB gun was supposed to load up before the firing.
    I did it where I didn't have to cut open the BB unit in case I wanted to revert back...
    I watched a video where it said I needed a "jumper" in channel 6, but I don't really want to clip off my existing wiring. Do I have any other options to synchronize it all?
  • SoCalBobS
    • 2754
    • Southern California
    Go online and buy a replacement plug for channel 6. You can get them with wires installed. Connect the two wires and that's your jumper. Amazon and eBay both carry them and they're dirt cheap. If you stay in the hobby you'll need more anyway.
      • 5402
      If you have any old LiPo or LiFe batteries the common balance lead plug is the same as the two pin H-L uses. A dremel will make a 3 or more pin connector a 2 pin. You can also buy a bunch of 2 pin off Amazon cheap. 20 of them are under $10. Here’s a kit of various pins.
