Official Heng Long 1/24 Scale Japanese Type 90 Airsoft and Infrared Battle Tank RTR Thread
    1/24 Scale Japanese Type 90 Airsoft and Infrared Battle Tank by Heng Long - RTR - HLG3808-001
    The Type 90 was the main battle tank of the Japan Ground Self-Defense Force, first entering service in 1990. Built by Mitsubishi Heavy Industries and operated by a 3-man crew, the 120mm smoothbore main gun was fed by an auto-loader, allowing for efficiency and a smaller number of crew aboard.
    Heng Long has manufactured industry-leading RC tanks for more than 20 years, and these 1/24 scale models deliver an economical, compact method for customers wishing to explore the world of RC tanks.
    Airsoft and IR Equipped
    The easily-accessible airsoft BB reservoir allows for exciting inter-tank battles or individual target practice to sharpen shooting skills, or battle without bullets using the included infrared system!
    2.4 GHz Radio System
    The interference-free 2.4 GHz radio system allows for multiple tanks to operate and battle simultaneously.
    Safe for young tank commanders
    The included cannon barrel plug allows young commanders to operate the tank safely with the airsoft function disabled and the barrel capped.
    Included Scale Details
    Supplemental scale details such as a tank commander, weapons, rope, and more are included with your tank.
    • 1/24 Scale R/C Battle Tank
    • Maximum airsoft BB firing distance of ~ 20m (60’)
    • Four topside LED lamps indicate IR battle damage status
    • Sound system produces realistic engine and gun firing effects
    • The turret rotates in both directions (total 320 degrees) and cannon barrel moves (30 degrees up/down)
    • Multi-wheel suspension system
    • 2-speed forward throttle control
    • Forward, backward, right turn, left turn, 360-degree spin and super-spin mode
    • Equipped with high-grip tracks for maximum traction
    • 2.4GHz radio control allows exciting multi-tank battles
    • Run time of more than 20 minutes per charge
    • LED lights add realism and play value
    • 7.4v, 1800mAh Li-Ion battery pack with convenient USB charger
    • Scale details like machine guns, chains, and tank commander figure included for incredible realism
    For safety, two transmitter buttons must be pressed simultaneously to shoot airsoft ammunition. A red warning light flashes when the tank is about to shoot, and the firing mechanism can be switched off by a separate switch hidden under the hatch. A red rubber plug is also supplied for the cannon barrel when operating in non-firing mode.
    • Heng Long Japanese Type 90 1/24 Scale Airsoft and Infrared Battle Tank - RTR
    • 2.4GHz transmitter
    • Airsoft BB ammunition
    • IR Battle Module
    • 7.4v Li-Ion rechargeable battery pack
    • USB Charger
    • Plastic scale details
    • Stickers (markings and details)
    • Instruction manual
    • Airsoft Target
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: 1 Hour
    Scale 1/24
    Length 38.1cm / 15in
    Width 20.3cm / 8in
    Height 10.2cm / 4in
    Weight 2.7Kg / 5.9lbs
    Body Material Plastic
    Chassis Material Plastic
    Track Material Plasticized rubber
    Motors Single 240-size
    Bearings Bushings
    Gearbox Gear Material Plastic
    Adjustable Gear Ratio 2-speeds FWD
    Differential Type Plastic
    Suspension Type Plastic
    Sprocket Plastic
    Road Wheels Plastic
    Idler Wheel Plastic
    Adjustable Idler No
    Turret Rotation 320 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect No
    IR Battle Ready Yes
    Airsoft BB Launch Yes
    Track Recoil No
    Cannon Barrel Recoil No
    Required Battery 7.4v (included)
    Required Radio 2.4GHz (included)
    Skill Level Beginner
    Build Time 1 Hour
