The German Leopard 2A5 main battle tank is a radically improved variant of the Leopard 2 and was introduced in 1990. By 1998, the Leopard 2A5 was referred as the best main battle tank in the world. The 2A5 has significantly improved armor protection compared to its predecessor, and the turret is fitted with additional wedge-shaped modular armor. Add-on modular armor panels were also fitted at the front of the hull. Damaged armor modules can be easily replaced in field conditions. New side skirts were fitted and interior of the vehicle is lined to prevent spalling. The Leopard 2A5 also received more powerful armament with an improved 120 mm smoothbore gun.
Heng Long has manufactured industry-leading RC tanks for more than 20 years, and these 1/24 scale models deliver an economical, compact method for customers wishing to explore the world of RC tanks.
Airsoft and IR Equipped The easily-accessible airsoft BB reservoir allows for exciting inter-tank battles or individual target practice to sharpen shooting skills, or battle without bullets using the included infrared system! |
2.4 GHz Radio System The interference-free 2.4 GHz radio system allows for multiple tanks to operate and battle simultaneously. |
Safe for young tank commanders The included cannon barrel plug allows young commanders to operate the tank safely with the airsoft function disabled and the barrel capped. |
Included Scale Details Supplemental scale details such as a tank commander, weapons, rope, and more are included with your tank. |
- 1/24 Scale R/C Battle Tank
- Maximum airsoft BB firing distance of ~ 20m (60’)
- Four topside LED lamps indicate IR battle damage status
- Sound system produces realistic engine and gun firing effects
- The turret rotates in both directions (total 320 degrees) and cannon barrel moves (30 degrees up/down)
- Multi-wheel suspension system
- 2-speed forward throttle control
- Forward, backward, right turn, left turn, 360-degree spin and super-spin mode
- Equipped with high-grip tracks for maximum traction
- 2GHz radio control allows exciting multi-tank battles
- Run time of more than 20 minutes per charge
- LED lights add realism and play value
- 7.4v, 1800mAh Li-Ion battery pack with convenient USB charger
- Scale details like machine guns, chains, and tank commander figure included for incredible realism
For safety, two transmitter buttons must be pressed simultaneously to shoot airsoft ammunition. A red warning light flashes when the tank is about to shoot, and the firing mechanism can be switched off by a separate switch hidden under the hatch. A red rubber plug is also supplied for the cannon barrel when operating in non-firing mode.
- Heng Long German Leopard 2A5 1/24 Scale Airsoft and Infrared Battle Tank - RTR
- 2.4GHz transmitter
- Airsoft BB ammunition
- IR Battle Module
- 7.4v Li-Ion rechargeable battery pack
- USB Charger
- Plastic scale details
- Stickers (markings and details)
- Instruction manual
- Airsoft Target
- Three (3) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
AGE LEVEL: 14 and up
SKILL LEVEL: Beginner
BUILD TIME: 1 Hour
| Scale | 1/24 |
| Length | 38.1cm / 15in |
| Width | 20.3cm / 8in |
| Height | 10.2cm / 4in |
| Weight | 2.7Kg / 5.9lbs |
| Body Material | Plastic |
| Chassis Material | Plastic |
| Track Material | Plasticized rubber |
| Motors | Single 240-size |
| Bearings | Bushings |
| Gearbox Gear Material | Plastic |
| Adjustable Gear Ratio | 2-speeds FWD |
| Differential Type | Plastic |
| Suspension Type | Plastic |
| Sprocket | Plastic |
| Road Wheels | Plastic |
| Idler Wheel | Plastic |
| Adjustable Idler | No |
| Turret Rotation | 320 Degrees |
| Lights | Yes |
| Sound | Yes |
| Exhaust Effect | No |
| IR Battle Ready | Yes |
| Airsoft BB Launch | Yes |
| Track Recoil | No |
| Cannon Barrel Recoil | No |
| Required Battery | 7.4v (included) |
| Required Radio | 2.4GHz (included) |
| Skill Level | Beginner |
| Build Time | 1 Hour |
| Recommended Environment | Indoor / Outdoor |
.png)
