Official Torro 1/16 Scale German Jagdtiger Tank Destroyer RTR Thread
    • 8233
    1/16 Scale German Jagdtiger Tank Destroyer from Torro - RTR - TOR1112200786
    The Jagdtiger ("Hunting Tiger"; officially designated Panzerjäger Tiger Ausf. B) is a German casemate-type heavy tank destroyer from World War II. It was built upon the slightly lengthened chassis of a Tiger II. Its ordnance inventory designation was Sd.Kfz. 186.
    The 71-ton Jagdtiger was the heaviest armored fighting vehicle (AFV) used operationally by any participant nation of WWII and is the heaviest combat vehicle of any type to achieve series production during the conflict. The vehicle was armed with a 128 mm PaK 44 L/55 main gun which was capable of outranging and defeating any tank or AFV fielded by the Allied forces.
    All Metal Track System
    All of Torro's "Pro-Edition" tanks feature full metal drive systems. Single track links are connected with steel pins, propelled by metal drive sprockets and riding over metal road wheels and idler. Confidently conquer terrain with these durable metal tracks!
    High Torque Motors
    Reliable metal geared gearboxes are driven by high torque motors.
    Heavy Metal Castings
    Hoist hooks, spare track links and even simulated "welds" are reproduced in cast metal! The iconic "Zimmerit" coating applied by tank crews to repel magnetic mines is also molded into the upper hull for additional period accuracy.
    IR Battle Ready
    Engage in friendly infrared ("IR") combat with other tanks using Torro's proprietary IR Battle System, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight!
    Onboard Charging
    Torro's convenient onboard charging system eliminates the hassle of removing batteries after every driving session. Safely charge the onboard NiMH battery by plugging the included charger's plug into the tank's concealed charge port.
    Superb Scale Fidelity
    Molded details, metal cast parts, brass photo-etched parts, and functional elements such as opening hatches all elevate this RC model to the next level, making it a perfect display piece when it's not powering through the battlefield outside.
    360 Degree Turret
    Fully rotate the metal turret 360 degrees, and move the all-metal barrel up and down to train on your target. Torro's integrated drive electronics gives you complete proportional control to translate your precise inputs to all axe of movement. Drive, turn, traverse, train, and fire!
    RTR
    The convenience of "Ready to Run" (RTR) allows new players to join the world of RC Tanks with ease!
    Features:
    • Latest Generation Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed, and low-speed modes, etc.
    • Smoke effect (On/Off)
    • Headlights and Brake lights (On/Off)
    • Volume (five settings including Off)
    • Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
    • Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Fires an invisible IR signal to be used as part of Torro’s Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    • Independent suspension on all road wheels
    Includes:
    • Torro German Jagdtiger 1/16 Scale Tank Destroyer - RTR
    • 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
    • 2S USB LiPo/Li-ion battery charger
    • 6-Channel 2.4GHz radio transmitter
    • Magnetic Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • 2x spare track links
    • Smoke oil
    • Complete instruction manual
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: 1 Hour
    Scale 1:16
    Length 66cm / 25.9in
    Width 23cm / 9.0in
    Height 20cm / 7.8in
    Weight 6500g / 229oz
    Body Material Metal/Plastic
    Chassis Material Metal
    Track Material Metal
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Bogie
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler No
    Turret Rotation 360 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V 1800mAh (included)
    Required Radio 6 Channel (included)
    Skill Level Beginner
    Build Time 1 Hour
  • Zippersnapper
    Insane Unknown
    • Mar 2021
    • 502
    • SW Texas
    Im waiting for this to be in stock....Pants on fire, as the money is burning a hole in my pocket. Please hurry ! By the way, is Torro any good?
    • sclui56
      • Mar 2021
      • 415
      • LAX
      Torro = Taigen with a wooden crate
      • Zippersnapper
        Insane Unknown
        • Mar 2021
        • 502
        • SW Texas
        Thank you sir, that makes sense...
        • Zippersnapper
          Insane Unknown
          • Mar 2021
          • 502
          • SW Texas
          Just purchased. The specifications & features listed above, I trust are accurate. If not, I will be a VERY unhappy customer.
          Turret Rotation- °360
          Cannon Barrel Recoil-Yes
          "360 Degree Turret
          Fully rotate the metal turret 360 degrees, and move the all-metal barrel up and down to train on your target. Torro's integrated drive electronics gives you complete proportional control to translate your precise inputs to all axe of movement. Drive, turn, traverse, train, and fire! "
          • oldwolf
            • Dec 2020
            • 266
            Lol, the turret does rotate 360 degrees when the the tank spins in place.
            • Rubicon99
              • 3316
              LOL😂🤣🤣🤣 this ^^^^^^^ is so true.
              Motion has been warned about the miss information on their tank listings many times now but doesn’t seem to care.
              • SoCalBobS
                • 2754
                • Southern California
                The Soviets called them "fixed turret tanks".
                • Zippersnapper
                  Insane Unknown
                  • Mar 2021
                  • 502
                  • SW Texas
                  Indeed......and you cant help but wonder in amazement the picture of the Tiger 1, under "Includes"
                  • Zippersnapper
                    Insane Unknown
                    • Mar 2021
                    • 502
                    • SW Texas
                    Hell, I would have been ok with °10 of rotation.
                    • bobassetto@me.com
                      • Aug 2021
                      • 33
                      • Philadelphia
                      Hi
                      I have one these that needs minor repairs…. I have the part…… FREE…. But no shipping must pick up
                      In feasterville, Pa 19053
                      Bob
                      bobassetto@me.com
                      • OSMD
                        • Mar 2020
                        • 48
                        Got one, let's hope it has no connectivity/signal issues.
                        • DavidN
                          • May 2021
                          • 3203
                          • Los Angeles, CA
                          My Torro Jagdtiger. This one came as the tan/dark yellow color version. I kept the same color so it can be blended in with many battlefield we have in southern California.
ID:	451781 Click image for larger version
ID:	451782 Click image for larger version
ID:	451783 Click image for larger version
ID:	451784 Click image for larger version
ID:	451785 Click image for larger version
ID:	451786 Click image for larger version
