Official Torro 1/16 Scale German Panther F Medium Tank RTR Thread
    • 8205
    1/16 Scale German Panther F Medium Tank from Torro - RTR - TOR1213879503
    The Panther is a German medium tank deployed during World War II on the Eastern and Western Fronts in Europe from mid-1943 to the war's end in 1945. It was designated as the Panzerkampfwagen V Panther until 27 February 1944, when Hitler ordered that the Roman numeral "V" be deleted. Contemporary English language reports sometimes refer to it as the "Mark V".
    All Metal Track System
    All of Torro's "Pro-Edition" tanks feature full metal drive systems. Single track links are connected with steel pins, propelled by metal drive sprockets and riding over metal road wheels and idler. Confidently conquer terrain with these durable metal tracks!
    Exhaust Effect
    Enjoy the added scale realism that an exhaust provides.
    Heavy Metal Castings
    Hoist hooks, spare track links and even simulated "welds" are reproduced in cast metal! The iconic "Zimmerit" coating applied by tank crews to repel magnetic mines is also molded into the plastic upper hull for additional period accuracy.
    IR Battle Ready
    Engage in friendly infrared ("IR") combat with other tanks using Torro's proprietary IR Battle System, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight!
    Onboard Charging
    Torro's convenient onboard charging system eliminates the hassle of removing batteries after every driving session. Safely charge the onboard NiMH battery by plugging the included charger's plug into the tank's concealed charge port.
    Superb Scale Fidelity
    Molded details, metal cast parts, brass photo-etched parts, and functional elements such as opening hatches all elevate this RC model to the next level, making it a perfect display piece when it's not powering through the battlefield outside.
    360 Degree Turret
    Fully rotate the metal turret 360 degrees, and move the all-metal barrel up and down to train on your target. Torro's integrated drive electronics gives you complete proportional control to translate your precise inputs to all axe of movement. Drive, turn, traverse, train, and fire!
    RTR
    The convenience of "Ready to Run" (RTR) allows new players to join the world of RC Tanks with ease!
    • Latest Generation TK6 Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed and low-speed modes, etc
    • Smoke effect (On/Off)
    • Headlights and Brake lights (On/Off)
    • Volume (five settings including Off)
    • Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
    • Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Fires a 6mm plastic BB (10 meters with minimal accuracy and limited velocity, but should still be treated with caution and with adequate eye protection)
    • Fires an invisible IR signal to be used as part of Heng Long's Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    • Independent suspension on all road wheels
    • Torro German Panther F 1/16 Scale Medium Tank - RTR
    • 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
    • 2S USB LiPo/Li-ion battery charger
    • 6-Channel 2.4GHz radio transmitter
    • Magnetic Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • 6mm plastic BBs (50 Pack)
    • 2x spare track links
    • Smoke oil
    • Complete instruction manual
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: 1 Hour
    Scale 1:16
    Length 41cm / 16.1in
    Width 18.5cm / 7.2in
    Height 17cm / 6.6in
    Weight 2267g / 79.9oz
    Body Material Metal/Plastic
    Chassis Material ABS Plastic
    Track Material Metal
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Bogie
    Sprocket Metal
    Road Wheels Plastic
    Idler Wheel Metal
    Adjustable Idler No
    Turret Rotation 360 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch Yes, 6mm
    Track Recoil Yes
    Cannon Barrel Recoil No
    Required Battery 2S 7.4V 1800mAh (included)
    Required Radio 6 Channel (included)
    Skill Level Beginner
    Build Time 1 Hour
