Official Torro 1/16 Scale German Panzer IV (Ausf. G) Medium Tank RTR Thread
    • 8205
    1/16 Scale German Panzer IV (Ausf. G) Medium Tank from Torro - RTR - TOR1110385902
    Representing the pinnacle of Panzer design in World War II, the Panzer IV series took the proven chassis of the Panzer III and added additional firepower in response to the Soviet T-34 and American Sherman. This Pro version features metal gears, metal tracks, metal drive, road, and idler wheels in addition to a metal hull and turret.
    All Metal Track System
    Confidently conquer terrain with durable all metal tracks that are easy to service.
    360 Degree Turret
    The turret rotates in full 360 degrees.
    Barrel Recoil
    The barrel has fully functioning recoil to further the scale realism and appeal.
    Exhaust Effect
    Glycerin-based "exhaust effect" simulates engine exhaust for added realism
    Heavy Metal Castings
    Heavy Metal Castings provide unparalled durability and strength.
    High Torque Motors
    The high torque motors provided the strength and power necessary to negotiate difficult terrain.
    RTR
    These battle tanks are Ready To Run right out of the box for your convienence. Unpainted versions will require painting if desired.
    Superb Scale Fidelity
    Torro tanks are designed with impeccable attention to detail and scale realism.
    • Latest Generation Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed, and low-speed modes, etc.
    • Smoke effect (On/Off)
    • Headlights and Brake lights (On/Off)
    • Volume (five settings including Off)
    • Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
    • Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Fires an invisible IR signal to be used as part of Torro’s Infrared Battle System, which disables other tanks when hit five times during simulated combat
    • Independent suspension on all road wheels
    • Torro German Panzer IV (Ausf. G) 1/16 Scale Medium Tank - RTR
    • 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
    • 2S USB LiPo/Li-ion battery charger
    • 6-Channel 2.4GHz radio transmitter
    • Magnetic Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • 2x spare track links
    • Smoke oil
    • Complete instruction manual
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: 1 Hour
    Scale 1:16
    Length 41.4cm / 16.2in
    Width 18.3cm / 7.2in
    Height 16.8cm / 6.6in
    Weight 4800g / 169oz
    Body Material Metal/Plastic
    Chassis Material Metal
    Track Material Metal
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Bogie
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler No
    Turret Rotation 360 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V 1800mAh (included)
    Required Radio 6 Channel (included)
    Skill Level Beginner
    Build Time 1 Hour
  • HvH909
    • Aug 2021
    Are these the mostly metal version?
    • sclui56
      • Mar 2021
      • 415
      • LAX
      Yes, except for the upper deck.
      • DavidN
        • May 2021
        • 3182
        • Los Angeles, CA
        Here is the unpainted Toro panzer IV tank that I bought. You can see what is metal and what is plastic :-)
        • OSMD
          • Mar 2020
          • 48
          Great looking tank, looks wise my fav, love the colors of the painted version which I think was used by DAK if I'm not mistaken.
          • Rudinater
            • Mar 2020
            • 76
            • Houston TX/Bend Or
            So what does it take to make this or other Torro tanks Tamiya battle ready?
            • Rubicon99
              • 3311
              If you have the V3 Torro control system you will need to select it to the Tamiya setting. Then you will need a Torro IR receiver or you could wire for a HL LegoDEI receiver. Torros IR receiver is the same as HLs old IR receiver and those work but no better then the new HL receivers.
              You will then have a tank that can fire and be hit by Tamiya protocol tanks. It will not take damage and should perform similar to the current HL battle system.
              To be 100% Tamiya protocol battle ready you need to change out the entire control system to one of the many aftermarket offerings and the associated IR compatibility receiver.
              • Brad G
                • Jan 2026
                • 4
                Brand new tank. My first Torro. I cannot figure out how to fire the main gun. It is the IR version so if I battle another tank how do i shoot? Where is the trigger button?
                • DavidN
                  • May 2021
                  • 3182
                  • Los Angeles, CA
                  Flick the left knob up.
                  • tank_me
                    • Feb 2022
                    • 1180
                    Did it come with the manual? The IR fires whenever you fire the tank if the IR receiver is installed (the blue thing that is round on top). In order to battle with Tamiya/Heng Long tanks it needs to have the IR converter installed (little blue box inside the tank). If you point your phone at the IR LED in camera mode, you will see the LED glow purple for a second or two. That's how you can test if it's working.
                    • Brad G
                      • Jan 2026
                      • 4
                      Thanks for the info. It does have a manual it was unclear to me how to fire a cannon shot with or without the IR installed. Also now that I am looking into it I am also not sure about the tank charging system. Seems like I have to take the tank apart everything I need to charge
                      • tank_me
                        • Feb 2022
                        • 1180
                        Torro tanks typically have a quick release latch that allows you to remove the upper deck. Just don't yank it off as there are wires connecting the top and bottom. You didn't state what kind of tank so I can't say where the latch is as it is in different locations based on the tank model.
                        • keilau
                          • Mar 2021
                          • 1812
                          • Windy City
                          The "quick release latch" is easy to spot and do not need manual instruction. Just use care as tank_me suggested. I have only one tank with Torro metal lower and plastic upper chassis. The design is good and easy to operate.
                          • DavidN
                            • May 2021
                            • 3182
                            • Los Angeles, CA
                            The trick to open is.....Whatever the direction you pull the latch at the bottom of the tank, you push the upper hull the opposite direction before pulling it up. The two hooks inside the tank are a bit wide, so you have to pull the upper hull to the opposite direction as far as you can to clear the hooks off.
                            • glocke12
                              • Mar 2025
                              • 59
                              I don't know why Torro puts the wrong charging information in their manuals. You have to open up the tank and remove the battery and charge it.
                              For firing, the left control stick operates the firing mechanism. Push it up.
                              • Brad G
                                • Jan 2026
                                • 4
                                Thank you sir
