Official Torro 1/16 Scale German Panzer III (Ausf. L) Unpainted Medium Tank RTR Thread
    Unpainted 1/16 Scale German Panzer III (Ausf. L) Medium Tank from Torro - RTR - TOR1113848001
    The Panzerkampfwagen III, commonly known as the Panzer III, was a medium tank developed in the 1930s by Germany, and was used extensively in World War II. It was intended to fight other armored fighting vehicles and serve alongside and support the similar Panzer IV, which was originally designed for infantry support.
    Faithfully recreated in 1/16 scale, Torro continues to grow its reputation as a producer of high quality, high functioning RC tanks. This Pro Edition of the Panzer III features more than 70% metal part construction, a 360 degree rotating turret, a realistic torsion bar suspension, and a barrel recoil and muzzle flash effect that fires in sync with the IR (infrared) battle system.
    This version is delivered as RTR (Ready to Run), meaning it is fully functional out of the box, but it is UNPAINTED, giving modelers more freedom to detail, paint, and weather their model to their final preference. For the pre-painted version, visit here.
    All Metal Track System
    Confidently conquer terrain with durable all metal tracks that are easy to service.
    360 Degree Turret
    The turret rotates in full 360 degrees.
    Barrel Recoil
    The barrel has fully functioning recoil to further the scale realism and appeal.
    Exhaust Effect
    Glycerin-based "exhaust effect" simulates engine exhaust for added realism
    Heavy Metal Castings
    Heavy Metal Castings provide unparalled durability and strength.
    High Torque Motors
    The high torque motors provided the strength and power necessary to negotiate difficult terrain.
    RTR
    These battle tanks are Ready To Run right out of the box for your convienence. Unpainted versions will require painting if desired.
    Superb Scale Fidelity
    Torro tanks are designed with impeccable attention to detail and scale realism.
    • 70%+ metal parts including turret, main barrel, tracks and drive system
    • 360 degree turret rotation
    • Barrel Recoil with Muzzle Flash effect
    • Realistic Torsion Bar suspension system
    • Metal lower hull, drive wheels, idler wheels, and road wheels
    • Single pad metal tracks connected with steel pins
    • Onboard charging system via charge socket
    • Proportional acceleration, steering, turret traverse, and gun movement
    • Realistic sound system and smoke effect generator
    • Fires an invisible IR signal to be used as part of Torro's proprietary Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    • Torro German Panzer III (Ausf. L) Unpainted 1/16 Scale Medium Tank - RTR
    • 7.2V NiMH battery with Tamiya connector
    • 7.2V NiMH battery charger
    • 6-Channel 2.4GHz radio transmitter
    • Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • Set of small parts and accessories
    • Smoke effect oil (vegetable glycerin)
    • Complete instruction manual in English and German
    AGE LEVEL: 14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: 1 Hour
    Scale 1:16
    Length 41.4cm / 16.3in
    Width 18.3cm / 7.2in
    Height 16.8cm / 6.6in
    Weight 4800g / 169.3oz
    Body Material Metal/Plastic
    Chassis Material Metal
    Track Material Metal
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Bogie
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler No
    Turret Rotation 360 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V 1800mAh (included)
    Required Radio 6 Channel (included)
    Skill Level Beginner
    Build Time 1 Hour
  • 761st
    • May 2022
    • 392
    I want it!
    • SoCalBobS
      • 2761
      • Southern California
      One caveat: A metal turret on a small chassis can be top heavy. I had a Mato P-III that literally flipped backwards while climbing a steep grade. Bent the barrel. Shouldn't be a problem on relatively level surfaces, though.
      • 761st
        • May 2022
        • 392
        Ouch!
