Heng Long Command Inputs
  • SoCalBobS
    • 2717
    • Southern California
    After trying to read in between the Chinese ideographs on the 6.0 and 7.0 instruction sheets, I’ve taken the time to write out my interpretations. I put the info on my phone notepad so I’d have them handy. You’re welcome to try and cut & paste or otherwise copy them. A real good one in the 7.0 list is K & B, which toggles the spin or no spin option. No spin means the tracks don’t go forward and backward at the same time to spin in place, which I understand most tanks couldn’t do.
    Heng Long Command Inputs:
    6.0/6.1 Boards:
    G & stick 1 up: toggle front light on/off
    G & Stick 1 down: toggle rear light on/off
    G & Stick 1 left/right: backing left/right trim
    G & Stick 2 left/right: forward left/right trim
    G & Stick 2 up/down: high/low speed
    A: machine gun firing
    B: laser aiming light
    B & A: Fire main gun, tank recoil, IR shot
    G & A: gun stabilizer (pending)
    G & B: toggle BB action on/off
    G & S: toggle WiFi on/off
    G & K: cycle sound effect selection
    K & S: cycle tank recoil selection
    V: toggle volume
    S: toggle smoke on/off
    G & Ignition: current switch selection (pending)
    7.0/7.1 Boards:
    G & Stick 1 up: toggle front light on/off
    B & A: fire main gun, tank recoil, IR shot
    G & A: tank gyro system (7.1 only, pending)
    G & K: cycle tank sound selection
    V & Stick 1 up/down: volume up/down
    G & V: cycle brake strength selection
    K & Stick 1 left/right: left or right hand control mode
    K & Stick 1 up/down: tank rotation speed up/down
    K & Stick 2 left/right: tank turn radius smaller/larger
    K & Stick 2 up: toggle auto loading shell on/off (7.1 only)
    K & Stick 2 down: toggle warning flashing lights (7.1 only)
    K & B: toggle spin/no spin
    G & Ignition hold down for 5 seconds: double current mode & mix control mode (?)
    Ignition & G & K: restore factory settings
  • Cecil
    • Sep 2022
    • 19
    • United States
    Magnificent work Bob. Thanks a lot for sharing.
      • 5392
      All the ones I need are on the back of the transmitters battery cover, aren’t they on yours?
      • DavidN
        • May 2021
        • 3189
        • Los Angeles, CA
        Thank you Bob! I emailed Toucan and got myself a 7.1S board at the price that you stated in the other post. I will use your interpretation list when it arrives.
        • SoCalBobS
          • 2717
          Use whatever you prefer.
          • 761st
            • May 2022
            • 392
            Archived. Thanks Bob.
            • SoCalBobS
              • 2717
              Missed one; G & B: BB action on/off. I've edited/added it to the list.
              • edwardyn
                • Aug 2021
                • 6
                Your topic reminded me of the story of how I too could not understand the assembly instructions for the RC version of the F16 because it was either in Vietnamese or Turkish. I decided to assemble it along the lines of "here's the fuselage, so you just have to glue the wings and stabilizers to it", but I couldn't do it, so I had to go to a new url for the pirate bay, and find the assembly instructions from that company in English. Eventually, I found the instructions and I was able to assemble it.
