Official Heng Long 1/16 Scale German Panzer III (H Type) Battle Tank Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    German Panzer III (H Type) Upgrade Edition 1/16 Scale Medium Tank RTR from Heng Long - HLG3849-001
    German Panzer III (H Type) Professional Edition 1/16 Scale Medium Tank RTR from Heng Long - HLG3849-002
Name:	heng-long-german-panzer-iii-h-type-upgrade-edition-1-16-scale-medium-tank-rtr.jpg
Name:	heng-long-german-panzer-iii-h-type-professional-edition-1-16-scale-medium-tank-rtr.jpg
    The Panzer III was used in various German campaigns in Poland, France, the Soviet Union, and North Africa. The Ausf. H variant utilized the 50mm KwK 38 L/42 cannon, with bolt-on armor added to the front and rear hull. The Panzer III's strong, reliable, and durable chassis was also used as the basis for the turretless Sturmgeschütz III assault gun/tank destroyer, one of the most successful self-propelled guns of WWII.
    By the end of the war in 1945, the Panzer III saw almost no frontline use, and many of them had been returned to the few remaining armaments/tank factories for conversion into ammunition carriers or recovery vehicles. A few other variants of the Panzer III were also experimented on and produced by German industries towards the last phases of the war, but few were mass-produced or even saw action against the encroaching enemy forces of the Americans, British and Soviets.
    This Upgrade version features steel gears and plastic tracks for an economical balance between durability and weight. Heng Long has produced RC tanks for over 20 years, and their products offer an ideal starting point for new customers wanting to explore the world of RC tanks. All of Motion RC’s Heng Long 1/16 scale tanks utilize the latest TK7.0 MFCB for outstanding control, performance, playability, and upgrade potential!
    Durable Tracks
    Confidently conquer terrain with lightweight yet durable tracks that are easy to service. Professional Versions feature metal tracks for the ultimate in performance and realism.
    Independent Suspension and Steel Geared Gearbox
    Reliable gearboxes featuring steel gears efficiently transfer power while independent suspension provide traction over rough surfaces.
    Airsoft BB Launch
    Safely fire 6mm plastic airsoft BBs at the included paper target at short ranges. *Take safety precautions and wear eye protection.
    IR Battle Ready
    Engage in friendly infrared ("IR") combat with other TK7-equipped tanks, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight!
    Scale Details
    The perfect balance of scale detail and practical operation, each Heng Long tank arrives factory painted and includes Cosmetic Accessory Parts to further enhance the tank's realism.
    RTR
    The convenience of the "Ready to Run" (RTR) format allows new enthusiasts to join the world of RC Tanks with ease!
    • Latest Generation TK7.0 Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed and low-speed modes, etc.
    • Smoke effect (On/Off)
    • Headlights and Brake lights (On/Off)
    • Volume (five settings including Off)
    • Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
    • Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Fires a 6mm plastic BB (10 meters with minimal accuracy and limited velocity, but should still be treated with caution and with adequate eye protection)
    • Fires an invisible IR signal to be used as part of Heng Long's Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
    • Independent suspension on all road wheels
    • Heng Long German Panzer III (H Type) Upgrade Edition 1/16 Scale Medium Tank – RTR
    • 2S 7.4v 1800mAh Li-ion battery with XT60 Connector
    • 2S USB LiPo/Li-ion battery charger
    • 10-Channel 2.4GHz radio transmitter
    • Magnetic Infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • 6mm plastic BBs (50 Pack)
    • 2x spare track links
    • Smoke oil
    • Complete instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 1 Hour
    Scale 1:16
    Length 35cm / 13.7in
    Width 19cm / 7.5in
    Height 20cm / 7.8in
    Weight 2390g / 85.3oz
    Body Material ABS Plastic
    Chassis Material ABS Plastic
    Track Material ABS Plastic
    Bearings Metal Bushings
    Gearbox Gear Material Steel
    Adjustable Gear Ratio Fixed
    Differential Type Gear
    Suspension Type Idler Arm
    Sprocket Plastic
    Road Wheels Plastic
    Idler Wheel Plastic
    Adjustable Idler No
    Turret Rotation 320 Degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch Yes, 6mm
    Track Recoil Yes
    Cannon Barrel Recoil No
    Required Battery 2S 7.4V 1800mAh with XT60 connector (included)
    Required Radio 10 Channel 2.4GHz (included)
    Skill Level Beginner
    Build Time 30 Minutes
