T90 Metal Tank Track Compatibility
  • cmdrcody
    "Grumpy"
    • Dec 2022
    • 228
    • Largo, FL USA
    Does it require a different drive sprockets or idler wheels for using either types of the metal tracks available for use on the T90? Specifically, the metal tracks with dual linkages and the metal tracks with single linkages. I received a message back when I inquired about the Mato dual linkage metal tracks that it was required to use their drive/idler wheels due that they may not be compatible with other brands. Can someone experienced give an explanation as to if this is false or true? Also, is there any issues with using the drive sprockets that have the anti-slip rings installed using metal tracks?
  • Meter Rat
    • 507
    • Argyll and Bute, Scotland
    I think some of the metal tracks are 1.5mm-2mm wider than the plastic tracks. I’ve not experienced this myself. Mine are single pin tracks, and work with a pair of aftermarket sprockets that have anti-slip rings. The only time it detracts is if there is a build up of grass in the sprocket.
    • RichJohnson
      • 1301
      Mato metal track most often requires their sprocket on most tanks.
      • cmdrcody
        "Grumpy"
        • Dec 2022
        • 228
        • Largo, FL USA
        Does anybody notice that I posted the original thread nearly a year ago. It's all past history!
        • MrChef
          • Jan 2023
          • 518
          • New York, Not the city
          There was a spammer that brought a bunch of threads up this morning.
          • cmdrcody
            "Grumpy"
            • Dec 2022
            • 228
            • Largo, FL USA
            I sent a message to the site moderator, Elbee, about it early this morning about those two persons, "guest" and "UnknownStranger".
            He'll take care of it.
