LA Tank Battle Event 1/14/2023
cannot wait. Trying to get my Panzer III ready. Servo elevation doesn't seem to work. Clark Board.
Don't just fly--WREAK HAVOC!!! -
Servo elevation needs to be enabled in the Clark board using the Sony remote in order to work. If it is not enabled, then the system defaults to ESC control and not PWM (servo) control.Comment
Until you get the Clark board configured correctly, you can use S-Bus but plug the elevation servo into the appropriate socket in your receiver. Not the best, but a temp fix.The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
it just spins the servo to the right. I messed with the radio but not the board.Don't just fly--WREAK HAVOC!!!Comment
Gathering 1-2x monthly/All Ages & Experience levels welcomeComment
So the weather report says rain by 10 am. I assume it will cancel the battle.Don't just fly--WREAK HAVOC!!!Comment
They canceled the event on tuesday because there is a lake sitting on the battlefieldRC tank parts and accessories I make
www.RichardSJohnson.net/id28.htmlComment
Ahh, I looked at Farcebook and that is a lake were we fight. Not much of a Farcebook user so I don't really remember to check there.Don't just fly--WREAK HAVOC!!!Comment
