M2 Bradley
I almost bought a Bradley kit from DKlM but wound up dumping the money into my second new in box leoaprd 1 kit.
I will definitely buy a TD Bradley or two lolRC tank parts and accessories I make
www.RichardSJohnson.net/id28.html -
Well this is fun. The more option we have for "Cold War" and modern "cross over period" armor the better. Now if the quality is there then this will be a winner for TD. The M2 is about the size of a Sherman or T34 which means it will be a in the "sweat spot" of size for IR battling.
Looks like torsion bar suspension. I wonder how they will handle the 25mm cannon noise? Well, I'm guessing we'll have close on to a year to speculate.The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
I guess I will wait to print Inkor's version of the Bradley until I see what this one looks like. I have tons of other tanks to print in the mean time. I typically like fully molded tanks over 3D printed anyway. 3D printed tanks are a lot of work to make look good and get rid of all the layer lines.Comment
I have access to 8k and 12k resin printers running high end engineering resins to print tank hulls and turrets. Nice and smooth finishes a lot less work then PLA prints. The prints are almost injection quality. In the next few years or so printing of both PLA and SLA will be indistinguishable from injection molding. Some of the stuff coming to market is amazing. Makes having those once "unobtainium" tanks a soon to be reality.I guess I will wait to print Inkor's version of the Bradley until I see what this one looks like. I have tons of other tanks to print in the mean time. I typically like fully molded tanks over 3D printed anyway. 3D printed tanks are a lot of work to make look good and get rid of all the layer lines.Comment
Take the time it is super easy and the results are night and day better then "line prints" especially on detail parts and flat surfaces. Just use high a quality resins. You pay a little more but the end quality is so much nicer.Comment
Inkor's 3d tank file sets are low resolution grade. They come out the same on a resin printer as they do on a line printer. Dont know what program he is using but his resolution is too low to make a good printed model.RC tank parts and accessories I make
www.RichardSJohnson.net/id28.htmlComment
I hope JVMConcepts will be active making accessories and variants....
Well this is fun. The more option we have for "Cold War" and modern "cross over period" armor the better. Now if the quality is there then this will be a winner for TD. The M2 is about the size of a Sherman or T34 which means it will be a in the "sweat spot" of size for IR battling.The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
I’m sure those guys are cooking up whatever they can they already make some great stuff.
Im getting full sets of track from them now too. Granted it’s a lot of work to assemble but it beats having nothing.RC tank parts and accessories I make
I believe it’s 1/15 to fit their standard trannysRC tank parts and accessories I make
1/15 wouldnt be too bad. I have an old 1/15 stug IV by Bandai, if my memory serves. Sadly the pot metal parts of the running gear have mostly disintegrated into dust. The model doesnt look all that out of place beside a 1/16 model but you can tell something is off.Comment
DKLM RC just posted a "functions" video clip on Facebook. I haven't copied a FB link before but here it is, seems to work.
Proprietary engine noises, auto cannon operation and noise, folding out TOW launcher with launch flash, smoke from right side mid-body, functioning turn signals in front, opening hatches and rear door, for a few. Carson says it'll be on his website in a few days. No word on IR. I'm guessing we'll have to stick with the Tongde board to keep the functions in the video.
And yes of course I'll be buying one!
Edit: looking at the video in more detail, the barrel recoils repeatedly during firing, with a machine gun type noise. Maybe it's hooked to the MG circuit. The TOW launcher acts like a main gun; one noise, with synchronized flash. This presents some IR options if the circuit is active on the board. Either mount the emitter in the TOW case and forego elevation, or mount it in the mantlet to allow pointing but activate it with the TOW. There is a short interval while the TOW launcher deploys, which could simulate missile travel to target!The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
Update: Carson says the IR is mounted in the TOW launcher. There is a hole next to the flash LED. So, you just gotta have the M2 on a level field when you fire! of course, there is some IR beam spread up/down as well as side to side, so you won't have to be exact.The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
.png)
