Use of servos with a 6.0 mfu
  • Sappo
    • Feb 2020
    • 346
    Is it possible to use servos with the 6.0 mfu?I'd like to change the recoil on the t34 to something more realistic
  • BcuriousR
    • 133
    • Colorado
    Not easily. 6.1 and 7.1 will wire directly to the board. For the 6.0/7.0, you could try this: https://heng-long-panzer.de/en/signa...er-taigen.html
    • DavidN
      • May 2021
      • 3200
      • Los Angeles, CA
      And it works. I have just gotten 10 barrel recoil units from RJ when I went to SD. I will gradually install those signal converter (from Germany) into 10 of my favorite tanks with the 6.0 mfu boards inside.
      • Zippersnapper
        Insane Unknown
        • Mar 2021
        • 502
        • SW Texas
        • keilau
          • Mar 2021
          • 1838
          • Windy City
          Zipper, the servo arm looks symmetrical in the recoil and return action with this adaptor. It looks very similar to the HL trigger motor recoil. With the HL 6.1/7.1 MFU, the barrel return is significantly damped to make it look realistic. Do you have an actual barrel recoil video of this setup?
          • keilau
            • Mar 2021
            • 1838
            • Windy City
            Do you have an video that demonstrates the barrel return action using the small adaptor board?
            • keilau
              • Mar 2021
              • 1838
              • Windy City
              Anyone has a first hand experience with the heng-long-panzer.de servo adaptor board? Does it show a damped slower barrel return like the HL 6.1/7.1 MFU? Or it has a fast barrel return just like the HL 6.0/7.0 MFU trigger motor recoil?
              • keilau
                • Mar 2021
                • 1838
                • Windy City
                Do you have a first hand experience with the heng-long-panzer.de servo adaptor board? Does it show a damped slower barrel return like the HL 6.1/7.1 MFU? Or it has a fast barrel return just like the HL 6.0/7.0 MFU trigger motor recoil?
                • DavidN
                  • May 2021
                  • 3200
                  • Los Angeles, CA
                  Here is how the barrel recoils after I installed the signal converter (adapter) into my tank which has the 7.0 board inside. For the 6.0 board, it should be the same too.
                  • DavidN
                    • May 2021
                    • 3200
                    • Los Angeles, CA
                    Here is one that was connected to the Henglong 6.0 board.
                    • SoCalBobS
                      • 2736
                      • Southern California
                      Looks really good, David.
                      • keilau
                        • Mar 2021
                        • 1838
                        • Windy City
                        https://www.youtube.com/watch?v=oBrkocc3Eyk
                        A servo recoil with the HL 6.1S MFU is supposed to have a fast recoil and a damped, slow barrel return.
                        It looks very similar to the HL trigger motor recoil with the heng-long-panzer.de servo adaptor board. The barrel recoil and return motion seem symmetrical.
                        • DavidN
                          • May 2021
                          • 3200
                          • Los Angeles, CA
                          That tank has the 6.1 board inside. You are asking for your 6.0 board.
                          • keilau
                            • Mar 2021
                            • 1838
                            • Windy City
                            The answer is "NO". You must have the 6.1/7.1 MFU pair with a servo recoil to make the T-34 recoil "more realistic".
                            It looks very similar to the HL trigger motor recoil with the heng-long-panzer.de servo adaptor board and a servo recoil. The barrel recoil and return motion seem symmetrical from DavidN video.​
                            The most unrealistic recoil is the one with servo gun elevation. The gun tilts up slowly AFTER the barrel recoil and return no matter which MFU you use. It is as bad as it can get.
                            • Rubicon99
                              • 3315
                              What you are seeing is the "reload" feature of the barrel elevating after the shot. This can be turned off so that it is just a straight recoil back and forward. The "reload" elevation is meant for use in the modern tanks like the Leopard and T90/72 which actually have to raise their barrels during reloading.
                              Tamiya has this feature built into the MFU for their Leopard 2 as well. You can't turn it off with the Tamiya system so at least HL thought ahead when they included it with the 6.1/7.1 systems.
                              • keilau
                                • Mar 2021
                                • 1838
                                • Windy City
                                Thank you for the clarification. The US Abrams does not have automatic reload. Does the barrel tilt during the manual reload?
                                • Rubicon99
                                  • 3315
                                  No. But the feature was added because HL sells vastly more Leopards and T90/72s then Abrams.
                                  • keilau
                                    • Mar 2021
                                    • 1838
                                    • Windy City
                                    Below is how a servo recoil and servo elevation works on a HL German Leopard 2A6 with the 7.1 MFU. (The OP probably included a few more function than a generic TK-7.1 MFU.)
                                    A few members said that they can duplicate this servo recoil with the HL 6.0/7.0 MFU with an adaptor board. But all the related videos I had seen show that it is no more realistic than the simple HL trigger motor recoil unit.
                                    On the T-34, you can use the 7.1 MFU to disable the gun tilting function which is unique to modern tanks with auto loading.
